Middle-aged Curmudgeon
Free 12-bolt rear - Kansas City area
Free 12-bolt rear. It's a put-together Frankenstein, but restorable if somebody feels so inclined. Probably more appropriate for a parts rear.
Here's what I know about it: 1. Removed from the project truck I'm building. It ran and drove fine. 2. Open rear; not a posi. 3. Narrow housing; correct for a truck up to about 70 & 1/2. 4. Has wide 5X5 axles installed in it. 5. As a result of points 3 & 4, the drums hang a third of the way off the shoes. 6. Brakes are trash. Cables are seized, etc. 7. Has a 1310 yoke on it. Never bothered to figure out the gear ratio, but I can if someone want's to know. The way it drove I'm guessing it's in the low three's.
Bret Check out the site's Truck Tech FAQ. Be a site supporter. My more-or-less pathetic build thread. Board members I've met: ------------------------------ Longhorn Man Dieselwrencher jholley big mike71 |
Re: Free 12-bolt rear - Kansas City area
ttt
![]() Join Date: Jul 2005
Great price ttt 4 you
The biggest problem people have, is other people Thou shalt be cool and not hassle ![]() Be a site supporter. ![]() The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2 |
ttt
If it doesn't move here try craigslist or kcsr.org
1972 Long Bed Cheyenne Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=285282 Waste my bandwidth and listen to some great tunes >> http://www.radioxenu.com (Live Shows with yours truly every Friday) |
Interesting. I'd never heard of kcsr.org. Not quite sure what to make of that site.
![]() Anyway, I'll give it another week or so and then Craigslist it.
Why did you remove it from your truck?
My truck started out life as a 3/4-ton. Somewhere along the way somebody turned it into a 1/2-ton. I'm restoring it back to the way it was so I hunted up a Dana 60, swapped it in and removed the 12-bolt.
I am trying to hunt down the parts to convert a 3/4 ton to half. Do you need any more parts? Do you have anything still from the front end? I have a complete 3/4 ton with front disks, manual stearing, and rear leaf springs with a Dana 60 if you would want to trade(I know you already have a rearend).
Yeah.. lots of imports there but there are some muscle cars and trucks here and there as well.
![]() Join Date: Dec 2008
KCSR is all bench racing, mostly 16-17-18 year olds with fart can cars...If you want to see some nice local rides check out purposebuilt.org , but just a warning, it gets a little graphic at times, good bunch of guys who will forget more about going fast than the guys on most sites will ever know
![]() If you just want to get rid of that rear, I can help out, I have a trailer that is still a six bolt (leaf spring), would like to make it more common 5 bolt, I would even give you the correct six bolt axles if you know someone who can use a correct rear assembly? |
#12 | |
#13 | |
If it had the correct axles, I would think it'd be sellable. No, I don't know anybody who could use it, but it'd probably be more desirable if it were put together with the right parts. In fact, my son and I may use it later in a '68 if I had the right axles for it. Shall we just trade axles? Remember, it's a narrow housing with wide 5X5 axles stuck in it. Works for me if it works for you!
Mine is a P/U bed trailer, It has the six lugs in it, you can have those, I wont need them if I have 5 bolt axles to go in and it does not use brakes so it does not matter to me if they dont work
#15 |
Something just dawned on me, why can't a 3/4 inc spacer be bolted in on each side of the narrow rear ends so the 71 1/2 up axles would bolt in?
#16 | |
The spacer idea would probably work great. Be pretty easy to do as well. The reason those later 5X5 axles work in the earlier housing is because the surface where the bearing rides is wider-- wide enough to make it work without eating anything up.
#17 | |
