#26 |
Re: Brake problem – cant lock them up
anyone know where to get that little tool cheap? the ones I have found on the net seem to cost alot.
#27 |
Also I found this link on bleeding the brakes.
http://jeepgarage.free.fr/OWN/brake%...20bleeding.pdf |
#28 | |
PITbut
What year and make is your rig.. I will get you your exact procedure.
New project. 1971 Twin Turbo blazer http://67-72chevytrucks.com/vboard/s...d.php?t=676047 My new YOUTUBE channel.. Videos of my truck and a current walk around. Lyrikz74 Youtube channel DONE! SOLD! ![]() My 1971 stepside build thread My Build Thread UPDATED 6/11. DONE and sold. |
#29 |
#30 | |
PITbut
Now if you have a 1970-1974 the bleed procedure is. LF, RF, LR, RR..... Let us know how that works...
#31 |
Grand PooBaa Member
Cant we all just get along. Combination Valve is what came on our truck that had drum and drum. Prop valves were disc and drum.
I know cause thats what I had before I converted to disc brakes in the front. |
#32 | |
PITbut
Its good, just want to make sure he gets helped right.
#33 |
Assuming by some strech the master was bled, by bleeding the entire truck, you may have old rubber hoses that are ballooning up when you press the brakes, thus not giving the force to the pads.
#34 |
Hmm I havent changed the rubber. But with more work then I know what to do with its going to be a few weeks before I could replace them.
#35 |
Oh and when you buy a new master there is usually a bleed kit with it, there is two caps that go into the outlets, I never 'bench bleed' on a bench, i install the master then leave the lines unhooked, and bleed in the truck. If you have a show truck i wouldnt recommend this because it will eat the paint, but if your truck is old and rusty, just catch the fluid with a cup when you bleed it.
#36 |
I hate to bring this up as it's kind of a cop out, but in a situation where the brakes are giving you problems, hunt down a good brake shop that will "power bleed" the system. Don't ask me exactly what they do. I think they hook something to all 4 wheels, open the valves and push fluid up the lines, but I'm not sure. All I know is when I had it done on my truck when I had a problem, the pedal DOUBLED in firmness. It didn't cost very much either ($30?).
#37 | |
thanks for the idea. I'll look into it. I dont have alot of time and doing a raod trip Friday. been working 14 hour days. most of the time I have been posting at work.
![]() Quote:
