Old 05-22-2009, 09:20 AM   #1
70k52wd
Blaze-Air
70k52wd's Avatar
Wheel stud replacement
I must have nicked a wheel stud on the rear during my build. I've never replaced one. How is it done?
70k52wd is offline   Reply With Quote
Old 05-22-2009, 09:34 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Wheel stud replacement
You just hammer the old one out.
To install the new one, you can insert it from the back, install a stack of flat washers on the front, and turn a lug nut around backwards and use an impact to pull it in.
I have done it many times that way, but the proper way is to use a shop press to press it in place. I bought a cheap Chinese press last year and will never go back. It's invaluable for stuff like this.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 05-22-2009, 11:34 AM   #3
70k52wd
Blaze-Air
70k52wd's Avatar
Thanks TX. I figured should ask first. I was concerned about doing wheel bearing damage. I guess a little PB blaster before hand wouldn't hurt either.
