Old 05-22-2009, 11:35 PM   #1
mnky30
mnky30's Avatar
finally got to drive my 66 on the road
well yesterday i went and started the registration prosses on my 66 gmc. i have no title for it so i have to get it inspected and weight certificate but for now i have a temporary tags. i drove my truck today and had some problems first the master cylinder is not letting the brake fluid back in to it so my front brakes were dragging real bad and had to bleed them off, then on my motor which is a 350 v8 it blow out the front intake manifold rubber and was blowing oil out. then my quadra-junk is having some major issuse and dieing out at stops. so got the truck home and took carb off and rebuilt it pulled the manifold and replaced the gaskets a rubbers and got a new master cyl and in stalled it. going to try again tommarrow. thanks for listening to me rant.hopfull better the next time.
vinnie
1960 chevy c10 frame with a 1966 cab
2002 dodge intrepid r/t
2004 chevy 2500 4 door short bed
mnky30 is offline   Reply With Quote
Old 05-22-2009, 11:47 PM   #2
mnky30
mnky30's Avatar
Re: finally got to drive my 66 on the road
here are pics i forgot them
vinnie
Old 05-23-2009, 07:40 AM   #3
jbgroby
jbgroby's Avatar
With all the problems you mentioned with your engine and brakes, it was still outweighed by the fact that you DROVE HER! YES!!
Here to a long and addictive quest to be the BEST! Great new! stick with it, just a little at a time. and it will all get done. I have a new spare single cell reservior for a 60 GMC should work with your 66, unless you have a dual setup for the clutch. You can have it for free just cover shipping. email me off BB at jbgroby@charter.net mention "master cylinder".
I'm now 9 years into an off frame (hurricane Katrina wipped me out) I should have her finished this year. I had so many different setbacks, I've almost given up once or twice.
Jake
jbgroby is offline   Reply With Quote
Old 05-23-2009, 11:20 AM   #4
mnky30
mnky30's Avatar
thanks for the offer but my truck has been converted to a brake booster and master cyl off of the doner truck i got. i had a 80 chevy c20 that i pulled the drive train off of and installed under my truck i have 3/4 ton 2wd front and rear installed the 350 and t400 trans here are some pics.
vinnie
Old 05-23-2009, 11:41 AM   #5
joe231
joe231's Avatar
COOL!!
you will want to ditch the rubber on the front and rear of the intake, just use some black RTV or "the Right Stuff"
those have been problematic for years and most people who do much engine work will tell ya the same, some gaskets don't even come with the rubber pieces, just come with a tube of silicone
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 05-23-2009, 05:54 PM   #6
mnky30
mnky30's Avatar
thanks for the info joe, if i have any problems with it again i will just use silicone
vinnie
Old 05-24-2009, 01:39 AM   #7
protrash64
Resistance is Futile
protrash64's Avatar
Glad to hear its moving.......you may need to adjust your brake rod out some. It sounds like it is applying pressure to the cylinder all the time. It needs some space before pushing on the 'piston' in the bore. I have seen this issue over in the suspension section a couple times recently.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
