So I got sick of my after market steering wheel being lop sided. So I took it off and put it on straight. Now the steering is very tight. It take unreasonable force to turn it. It's still drivable but just a pain in the a$$. (or arm really
![]() Anyway I took it back off and inspected everything and it all looks good. I was very careful to make sure everything went back together properly. And still same problem. Am i just ![]()
83' internally ballanced 383 Stroker, 400 turbo 3800 stall , Posi, 750cfm carb, Weind manifold, long tube headers, and a handful of other goodies. Custom billet and woodgrain interior. |
Re: steering feels tight
feedback anyone?
#3 | |
An after-market 'wheel has an "adapter" of some kind to mount it. I would check for clearence around it. You may have to take the 'wheel back off to do it though.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
2-door hoe
tilt colum
if so theres this bearing coller that can get bent if your not careful.....also is the wheel hitting the colum?........or you blew the powersteering belt off? |
Well the belt and fluid are fine. It is tilt steering though. How do I get to the bearing collar? And what makes it bend? to much torque tightening the wheel?
I have looked to see about taking apart the steering column but it seems like there is no way in??
