PB Dropmember Track Width???
I'm interested in getting DM, but am concerned about track width being to narrow? I'm planning on new wheels soon and the big brake spindalls upgrade from CPP wich narrows the track width 1 1/8. Are these DM built to order, can Nathan make DM to standard width???
A guy with a truck
Re: PB Dropmember Track Width???
Nate is usually pretty good about doing custom work- or has been for me. The limiting factor will be the width of the steering rack. You could always get a set of wheels with 1" less BS and a fatter lip...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
If you are looking for a big brake kit to use with the DM, I offer the 13" McGaughy's kit. It includes the rotors, dual piston calipers, hardware, and spindles. I don't have the price in front of me (all my info. is at the shop). I will post it up on Tuesday. It is very reasonably priced, and does not narrow the trac-width like the CPP kit. If you're stuck on using the CPP kit for whatever reason, I can build you a DM with a wider trac width.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
Okay! I will be looking for your prices then, thanks!
