Old 05-25-2009, 12:49 PM   #201
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
Re: Finally seeing some progress...
Looking good, I like the clean appearance of the single window. What are you doing for a mirror?
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
Old 05-25-2009, 12:56 PM   #202
NWD02
Peep mirror... not my first choice but for now that's what I'm planning on. Might change it later not sure.
NWD02 is offline   Reply With Quote
Old 07-06-2009, 06:27 PM   #203
AGRV8D
Regular Confuser
AGRV8D's Avatar
lookin good NWD
My Stuff
Surgeon General never said anything about smokin' Fords.
Build Thread
AGRV8D is offline   Reply With Quote
Old 07-06-2009, 11:50 PM   #204
NWD02
Hey Josh call me when you get a chance.
Old 07-07-2009, 03:48 AM   #205
hotrod 80
mini truck racer
hotrod 80's Avatar
Looking good Nick . Sorry if i was out of it when you called , working long hours @night right now .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 07-07-2009, 04:33 AM   #206
NWD02
No problem. Feel free to give me a call though, I went to nights in March, 10p-6a.
With the help of a friend I've been making little progress with the wiring. He's been teaching me as he does the wiring.
Old 07-07-2009, 09:03 AM   #207
my67chevytruck
Under Construction
my67chevytruck's Avatar
Nick, learn all you can.... I may need the help
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 08-07-2009, 09:52 PM   #208
NWD02
Ok, I finally got some more work done. It's no longer a single-legged chicken. I installed the posi unit I bought from a board member. It's was awesome and super easy. Thanks Raland for cleaning the unit up before I got it from you. I had never changed one out before so a good friend helped me out. Here's a few pictures of before and after.
Tomorrow I hope to finish up the wiring and install the speaker and radio. I'll post more pictures as soon as I do.
Old 08-07-2009, 11:07 PM   #209
my67chevytruck
Under Construction
Nice progress Nick!
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 08-09-2009, 05:54 PM   #210
NWD02
Thanks Heath. I think I just need to finish wiring, drive shaft and brake to make it drivable.
Old 08-09-2009, 06:22 PM   #211
my67chevytruck
Under Construction
you are very close bro! nice to see such steady progress. did you ever get that tailgate band mounted?
I may want to borrow your dash control idea, as that is the vintage air controller we will be going with.....
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 08-09-2009, 09:17 PM   #212
Hart_Rod
Hart_Rod's Avatar
Great progress! Is that an eaton or a gov lock?
Hart_Rod is offline   Reply With Quote
Old 09-21-2009, 05:47 PM   #213
NWD02
Ok Heath... You've been making me look bad with all your progress. Today I actually did something. The fuel lines are completely finished. I got the rear drums installed. I installed new everything on the rear brakes, springs, pads, drums (I even painted them gloss black), wheel cylinders, etc. I also finished installing the lights. I wasn't a fan of the clear taillight lenses but, I found a good deal locally on a set for only $10 so I figured I'd see how they look with my LED tail/brake lights. THEY LOOK AWESOME!!! I haven't turned the truck over since I broke the cam in back around November of 2008. I have the wiring almost finished so I had to test the ignition today, so I turned it over again. Talk about motivation... it started right up no hesitation...WOW!!!! It sounds sooo good!!! I'll post some pictures shortly.
Old 09-21-2009, 06:02 PM   #214
VA72C10
VA72C10
VA72C10's Avatar
Did you ever get the tailgate skin installed?
Old 09-21-2009, 06:44 PM   #215
NWD02
Ok, here's a few pictures I just took. I have not installed the tailgate panel yet. The tail light picture is just the tail light (not brake) and reverse light. The fuel line had to be ran on top of the frame due to my exhaust being ran inside the frame. I had ordered a vintage air kit with servo controls. MEKDAD was able to take an idea I had and make it happen with the A/C control panel. If you look behind the motor down low there are two bulkhead with braided lines connected to them. One is going to be connected to the top of the intake the other to the right side of the tranny near the dipstick. All of my wiring to the engine and starter are ran through the lines. Its a work in progress but coming together.
Old 09-28-2009, 11:05 PM   #216
es67chevy
es67chevy's Avatar
time for me to subscribe to follow the process. About to go through several of these same steps myself. truck is looking really nice. Braver than me tackling the gears!!!
Eric
1967 C10 SWB
383 Stroker/TH400
Brother's One Piece Power Windows
Shaved Doors, Markers, and Bumpers
4/6 Early Classic Drop
Rear Fuel Tank (49-52 Chevy Car Tank)
Surf Blue Paint
Bella Vista, AR (Arkansas for those that get the 'A' states mixed up)
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=330869
es67chevy is offline   Reply With Quote
Old 09-29-2009, 07:29 AM   #217
my67chevytruck
Under Construction
Nick,
you flew past me along time ago bro! Truck is moving right along, execellent work... Since you are the wiring king now, i need to send my sons '67 to you when the time is right! Keep up the great work, and you will be driving her in no time!
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 09-29-2009, 07:59 AM   #218
NWD02
Heck I didn't have the time nor the patience to do the wiring. I got to watch and lend a helping hand here and there but a friend of mine that works at a local Chevy dealer did the work. We were up late last night and he has a little more to do and he'll be finished. I've pretty much decided not to put the one piece windows in. I'm tired of trying to line them up. I think I'm just going to get some vents and go with the stock look.
Old 09-29-2009, 10:39 PM   #219
my67chevytruck
Under Construction
Nick,
Sorry to hear about the windows, but i feel your pain, i am still not satisfied with the 1 piece windows in my '56 . I need to find a friend like that
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 10-02-2009, 12:33 PM   #220
hotrod 80
mini truck racer
hotrod 80's Avatar
Just caught up with the thread and bumping for updates and Happy Birthday .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 10-02-2009, 03:58 PM   #221
NWD02
Thanks.
Old 10-02-2009, 08:19 PM   #222
franky69c10
chevy runs deep
franky69c10's Avatar
Looks good bro
RAIDER NATION
1969 c10 swb soon 2 b on the road...
My LWB is a SWB now
http://67-72chevytrucks.com/vboard/s...d.php?t=498241
franky69c10 is offline   Reply With Quote
Old 10-02-2009, 11:34 PM   #223
nuke1
nuke1's Avatar
Happy B-Day, and she looks good, lights are awesome!!!, glad you gotto hear her, and i agree on the one piece, i love them, but i have to do some serious work to make them work, argh, aftermarket junk
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 10-03-2009, 12:16 AM   #224
NWD02
Thanks nuke. The window kit looks really good and is awesome, as long as it's installed by someone else.
Old 10-16-2009, 10:40 PM   #225
NWD02
More pictures... I set the seat in and bolted it through one of the original holes on each side. It's going to get mounted soon, when it goes to the upholstery shop to get the floor carpet, tank carpet, custom kick panel carpet covers, custom door panels made and installed.
The motor pictures are my new valve covers my wife surprised me with for my birthday. They came from pmlcovers.net, AKA Moe's Performance. I picked up the air cleaner from O'Reilly's and just set it on top for the picture. I need to do the throttle linkage before I mount it for good. Slowly getting there.
Ok... is it me or is the picture attachment function not working?
