Re: The Project Havoc....
Sorry, but i did not have time to get it done this wekend. but i will get to it very soon. K.
Well i spent most of the weekend out in the shop. I got 90% of the brake lines done on the truck. Ran my crappy rubber fuel line that is gonna be temporary, till later. Made a bracket for my fuel pressure regulator, got the rad mounted with my homemade speacial brackets, wowzers, eh. As i was mountint the rad, i soon realized that my rad support is bent, it will do for now, but i am gonna look for a new one now. go figure. I also got my power steering pump and hoses put on. the pressure hose is nice, but i had to do a funky adapter on the return line by the pump, but you barely see it. Spent quite awhile and got all of the pulleys lined up, except the water pump, need a shim, which is on order and i also got the headers finally bolted on for good. no more taking them off. I think that is what i got done, enuf rambling for now. Talk to you later. James Total Hours:299hrs
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
