Old 05-23-2009, 10:30 PM   #1
nu2-72
next problem,spindle shim?
When I tore down the truck, there was a shim behind the RF spindle. Stupidly, I thought nothing about it at that point and took it out. Later as I cleaned the parts I found that this thing is a wedge. It is tapered. Now I have no idea which way the thick side went.
At this point my plan is to use a machinist level and level the frame side to side. Then check the axle tubes and then the spindles. I am hoping that this will tell me if the spindle is kicked up or down and where the shim goes.
Anyone have any experience with this shim or ever seen one?
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
2004 Duramax Silverado 4x4
2006 Duramax Crew cab 4x4
2010 Harley Ultra Limited
2011 Harley Street Glide
nu2-72 is offline   Reply With Quote
Old 05-23-2009, 10:51 PM   #2
msgross
msgross's Avatar
Re: next problem,spindle shim?
you have a pic? I remember a flat thrust washer but no shims...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 05-24-2009, 07:26 AM   #3
i`d do what you plan...level axles and check square/plumb of spindle base @ knuckle.Most likely it was installed to camber-out or tilt the top outward,putting the shim at the top.Just the nature of wear and and gravity usually puts the top at a lean inward.It`s pretty rare to need those shims on an alignment.I`ve never needed one.
You might also check for a straight line across the tubes.It will be a very minor difference.You`d have to pull a string or lay a straight-edge across at a given height off the axle tubes at each end.Then,check towards the center for a dip or crown.Usually it`s an axle tube "settled",giving a larger number at the differential housing.It`s either the tubes not truly inline or a tilt to the knuckle in relation to the tube(how it was assembled,usually).It takes alot to move these...very rare.Usually it`s how they were originally assemble.Just a tad off.
Old 05-24-2009, 08:40 AM   #4
LONGHAIR
Special-k is absolutely correct. These are "alignment" shims, intended to make up for a camber problem. I have only ever seen one that that was from the factory (as far as we could tell). The rest were done to make up for what could really only be bent parts....the tube or the C bracket. I think I only ever saw a half dozen of them in over 10 years working in a place that specialized in 4x4s.
It probably goes with the widest part toward the top, or close to it.
"Hopefully" you have both sides apart...and the shim is only under one side.
If so, I would "adjust" the jack-stands to make the spindle-flange area of the knuckle on the side w/o the shim so that it is perfectly plumb. Then, check the other side. Put the shim to get it perfectly plumb too.
When the weight gets back on the truck, there will be the slighest bit of negative camber. Be sure to measure for "toe" after you put the wheels back on.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 05-25-2009, 02:03 PM   #5
nu2-72
here is the shim for those wondering what I am talking about.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
Old 05-26-2009, 05:48 AM   #6
Let us know what you figure out.I imagine you`ll need some careful set-up and measuring.It won`t be that far off.
Old 05-26-2009, 06:13 AM   #7
Blazer1970
Blazer1970's Avatar
I would leave it out and put the truck back together. If you think you have an alignment problem when it is done, take it to a shop to be checked. I think a lot of alignment guys put those things (and the eccentric ball joint adjuster sleeves) in there to justify their fee.
Blazer1970 is offline   Reply With Quote
