Old 03-25-2003, 12:43 AM   #1
chevy2racr
So Many Ideas, So Little Money
chevy2racr's Avatar
700R4 guys, clearances? how tight?
how tight does it fit in a low hump cab? anyone have one in withte motor inthe I-6 location? just curious how tence it will be in there
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors
71 C10 with 454
99 S-10 5.1L SBC 700R4
09 Malibu
Marshalltown, Iowa
chevy2racr is offline   Reply With Quote
Old 03-25-2003, 10:04 AM   #2
ckhd
ckhd's Avatar
I don't have one in a low-hump, but it's not really bigger than a T-350. It's longer, but not really bigger. I'd bet it would fit fine. Especially if you move your engine forward to avoid cutting the driveshaft...
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 03-25-2003, 12:36 PM   #3
Project1970
14.1 @ 96MPH
Project1970's Avatar
I have one in a low-hump, but the V8 is in the original V8 position...it worked great for me, I don't recall having to clearance anything...
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 03-25-2003, 10:48 PM   #4
Eddie H.
Eddie H.'s Avatar
There is no problem putting a 700r4 in a low hump cab.
If this picture attachment works, you can see that it is not any bigger than a 350 or 400 tranny.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 03-25-2003, 11:31 PM   #5
chevy2racr
chevy2racr's Avatar
no one knows if its in the I-6 location thought? front to back in the hump area no problems at all?
71 C10 with 454
09 Malibu
Marshalltown, Iowa
Old 03-26-2003, 10:06 PM   #6
chevy2racr
chevy2racr's Avatar
ttt
71 C10 with 454
09 Malibu
Marshalltown, Iowa
Old 03-30-2003, 01:26 AM   #7
nate68
mine's in the 6 location. there's a lip under there that i hadta bend a little bit cuz it was gonna hit (low hump cab)
68 short step, 406/700r4, 9" w/discs.
nate68 is offline   Reply With Quote
Old 03-30-2003, 02:44 AM   #8
chevy2racr
chevy2racr's Avatar
just one lip? clear take it out or just trim it some? pics would be helpful thanks nate
71 C10 with 454
09 Malibu
Marshalltown, Iowa
Old 03-30-2003, 10:57 AM   #9
Reumster
L.E.D. Freak
Reumster's Avatar
You will have no problem installing a 700R4 The case of the 700R4 is the same size as a 350T You may have to relocate your tranny crossmember
Specializing in Custom L.E.D. inserts.
http://www.ccled.com/
Contact me @ blazer2wd1972@hotmail.com
(406)675-8082
or Joel @ jmcwaters@eps-corp.net
1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL
Reumster is offline   Reply With Quote
Old 03-30-2003, 12:13 PM   #10
Slammed67
Progress = 0%
Slammed67's Avatar
You'll have clearance issues mounting it in the I-6 location. The pic below shows where it'll hit the hump. I fixed this problem by shortening my motor mount stands. That solved the problem, plus pulled the distributor away from the firewall slightly so there is no HEI-to-firewall interference
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 03-30-2003, 11:37 PM   #11
chevy2racr
chevy2racr's Avatar
ok Jason, tell me how ou shortend your motor mounts and I'll think about giving you some credit, like, say ur not 100% stupid just playin man, drop me a line or catch me online sometime
71 C10 with 454
09 Malibu
Marshalltown, Iowa
Old 04-02-2003, 12:15 AM   #12
chevy2racr
chevy2racr's Avatar
ttt
71 C10 with 454
09 Malibu
Marshalltown, Iowa
Old 04-02-2003, 06:22 PM   #13
John Fabris
TOTY 2006
John Fabris's Avatar
I glad you started this thread. I thought I had mine engine (350) in the V8 postition, and I have not yet tighted my cab mounts, and my cab is touching the 700r4 tranny. Is it possible that the rear tranny mount is taller then what is used for the 350turbo???
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 04-02-2003, 10:27 PM   #14
chevy2racr
chevy2racr's Avatar
TTT Jason, where are you?
John- where is yours hitting?
71 C10 with 454
09 Malibu
Marshalltown, Iowa
