Old 05-24-2009, 06:45 PM   #1
mothertrucker424
mothertrucker424's Avatar
no more 2wd to 4wd
ive decided to be content with my 2wd and install a locker for traction aid what do ya'll recommednd i know this is 4x4 section but i need help
i have a 2wd 2 door silverado with 4.3 and auto trans
_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
1972 K10 4"lift 33"tires (soon to be bigger and better)
2000 silverado 1500 2wd 2"coil spacers3" BL 285/75/16's
mothertrucker424 is offline   Reply With Quote
Old 05-24-2009, 07:18 PM   #2
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Re: no more 2wd to 4wd
I'd go with a posi. It will be easier on the tires when you're are the street
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 05-25-2009, 06:07 PM   #3
mothertrucker424
Do you know if its a gm 12 axle it looks like one but not sure
Old 05-25-2009, 06:11 PM   #4
Chevy1TonFun
Grease Monkey
need a pic of the diff cover. but that sounds right
Old 05-27-2009, 08:03 PM   #5
Mike C
Mike C's Avatar
I would look at doing an Eaton E-Locker or Detroit Electrac. These units are positractions. The Eaton is a clutch type and the Detroit a gear drive Tru-Trac type. Then you push a button and they are truly and completey locked. The best of both IMO. Another option would be an Ox Locker, but I like the others better for a streeter, especially a 2x4.
Edit: the Auburn Ected is another choice for a limited slip & then locker with the push of a button
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
