Power brake conversion
I have a 65 chevy c10 with drums all around. I am planning on converting to power brakes later. I would like to get a power booster from the u-pull-it place here but am not sure what year vehicles I should get one off of. Could someone lead me in the right direction. Seems like a easy job. From what I understand I need the booster, bracket and push rod.
60-66 Nut
Re: Power brake conversion
Check out the link in my sig for a couple of options for brake boosters. The booster bracket that I make and sell makes it a bolt on deal except for the pushrod modification. If you don't have the equip to weld, once you mark where the two rods need to be spliced together, any good fab shop should be able to get the job done for you at a reasonable cost.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 05-28-2009 at 12:32 AM. |
