Rocker Panels / Door jambs
Can anyone point me to a "step-by-step" article on R/R of rocker panels? The tops of my door openings (where the seal runs) have holes also. I think water got in through the screw holes where the rain channel is attatched.
I've never done anything like this before, but what the heck I never welded before either then I had to teach myself at work, now I love it! So I gotta try this. BTW it's an '81 Silverado 1/2 ton. Thanks for any help at all. |
Re: Rocker Panels / Door jambs
Thank you slash. Although I gotta say it looks pretty intimidating. I better line up a ride to work for a few days as I think the first one may take me more than a weekend.
lucky knuckles
...i'm going to maitland autobody tomorrow for a 4 wheel alignment (my truck's leaning left as the rear axle has shifted slightly) i'll see if he can give me a ball park on the cost for remove and replace rockers. it's gotta be pretty routine.
i've got some nasty snaps from a PO's tonneau cover and some ghastly riveted aluminum trim i'd like smoothed out. i'll letcha know the numbers and the service level. whereabouts in the city murderful you at? i'm downtown. |
We live over near Seaworld in Willamsburg. I have of course done searches online for rocker repair. But so far, found nothing like the article you've sent. I'll keep searching for more detailed step by step. I'm trying to find an article that will be helpful, and allow me to attempt this myself.
One shot, one kill.
John, I did mine and have some pics I can send you of whats involved. It is by no means an easy chore. Mine was a horror story the rust was so bad as you will see. The pics won't fit here but you can resize them and post them if you like. If you order rockers from LMC don't bother with the backing plates or panels, they are crap, just make your own from 1
\16 stock sheet metal. My e-mail is jmcclur2@nycap.rr.com. Jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shot ![]() |
#7 | |
After some more digging around, I found the "footwell?" is rotting out also. That's how the water is getting in. I had to toss my jute, & carpet cause it was wet & rotted. So are those spot welded also? LMC sells them along with the other patch stuff.
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
This is some pics from a customer installing our 5 piece cab repair kit.
http://forum.73-87chevytrucks.com/sm...p?topic=5661.0
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
Many thanks to you Chris for that step by step. I will read, & re-read before I start anything. I guess this isn't your average "get it done on a weekend job". I'm also trying to get an 80 gallon compressor as mine is in worse shape than me. I've had it 30 years, and I'm tired of fixin' & rebuilding it. I appreciate everyone's help and great suggestions.
No problem.
