05-27-2009, 09:42 PM | #1 |
PIMPING RIDES
Id this engine
block 9670014 i know they are camel hump heads
1964 CHEVY 1/2 C/10 FLEET 1981 CHEVY 1/2 C/10 FLEET 1995 DODGE 1500 V6 FLEET EAST http://www.flickr.com/photos/bigasspimp/?saved=1 |
05-27-2009, 10:07 PM | #2 |
James
Re: Id this engine
This could be it......
1968-76 3970014 350 - - 2 car,truck Many times a number will appear to be another with casting numbers.
Never crush'em. Restor'em or recycle'em. The payoff is always worth it in the end. http://viewmorepics.myspace.com/inde...lbumId=1709080 http://s258.photobucket.com/albums/h...e_top_view_all |
05-27-2009, 10:10 PM | #3 |
James
Re: Id this engine
Another find.....
1970-73, 3970014, 350ci, hp/low200 hp/high300, main2/4, LA built Camaro
05-27-2009, 10:13 PM | #4 |
James
Re: Id this engine
Do you happen to have a suffix code to go by? I may be able to narrow it down for you.
05-27-2009, 10:18 PM | #5 |
PIMPING RIDES
Re: Id this engine
but it is stamped 9670014
05-27-2009, 10:22 PM | #6 |
James
Re: Id this engine
Well, If that is the actual number then I dont know what to tell ya. I couldn't find it anywhere.
05-28-2009, 12:35 AM | #7 |
60-66 Nut
Re: Id this engine
Larry, see if you can find the numbers and letters stamped on the pad just in front of the passenger side head.
05-28-2009, 12:49 AM | #8 |
Resistance is Futile
Re: Id this engine
That intake is definitely older....the oil filler tubes were gone long before the 70's IIRC. No accessory bolt holes on the heads make them pre-68/69. Doesnt really ID the engine.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
05-28-2009, 01:20 AM | #9 |
James
Re: Id this engine
Yes, a suffix code would definately help in the id Of this motor. I would clean up that casting number to get a better look. I have had several motors that have had parts of casting numbers look like another number. And also, If for some reason you cant figure out what you have fron the casting number, Open it up, run the parts numbers like, crank and cam. And determin cylinder bore size. Check the charactoristics of the block and try to match them to either pre 68 or later.
Don't get me wrong here. I'm no pro at this stuff. I'm just throwing some suggestions out there. Good luck with it.
05-28-2009, 01:26 AM | #10 |
James
Re: Id this engine
Oh I just happened to notice that the oil dipstick is located on the
right side/driver side of the engine. That location of the dipstick is consistant with 68-76 blocks.
05-28-2009, 02:02 AM | #11 |
PIMPING RIDES
Re: Id this engine
the owner says it's a 327 he says it ru ns good .i want to put new camshaft ,timing chain ,get the heads worked .put a diff distributor , he want 150 for it hes a good friend so i think ill take it
05-28-2009, 02:09 AM | #12 |
James
Re: Id this engine
Sounds like a good deal. I have a 350 block with a 327 crank. It basically makes it a 327 except for the cyl. bore which makes it something like a 329. Anyway, my point is that it is entirely possible that the motor is a 327 even though the casting number says it's a 350.
05-28-2009, 02:12 AM | #13 |
James
Re: Id this engine
A few more little things to do to it and it'll be ready to fire. Can't wait to hear it.
05-28-2009, 09:47 AM | #14 | |
PIMPING RIDES
Re: Id this engine
05-28-2009, 11:12 AM | #15 |
James
Re: Id this engine
I'm not sure if those intakes are made anymore. But if you like the one you have, take it to a machine shop and get it hot tanked. Should clean up nicely. With proper preping, and a few coats of high heat paint, it should last you a long time and look great.
05-28-2009, 11:31 PM | #16 |
60-66 Nut
Re: Id this engine
It would be my guess that it is a 350 block, although they may have used the same block for the large journal 327's. Both the 327's and 350's had a 4 inch bore. The difference is the stroke of the crank and the pistons. For $150 that is a good deal.....the heads alone are worth that to some people. That would be a sweet engine for your truck with the right parts.
05-28-2009, 11:37 PM | #17 |
Re: Id this engine
check out this chart for SBC bore and stroke
http://www.aces.edu/~parmega/sbc.html says the 327 and 350 share the same 4 inch bore...
CHEVY ONLY Last edited by joe231; 05-28-2009 at 11:39 PM. |
05-28-2009, 11:53 PM | #18 | ||
60-66 Nut
Re: Id this engine
05-28-2009, 11:54 PM | #19 |
Re: Id this engine
Sorry John...I missed that little tidbit in your post
CHEVY ONLY |
05-29-2009, 12:10 AM | #20 |
60-66 Nut
Re: Id this engine
No problem.......
