Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 05-25-2009, 11:15 AM   #1
rigon4
rigon4's Avatar
what to do about trans???
OK I have a 85 short step 502/th400/411s I bought it in march with a bad trans. I went and bought a new trans put it in and 2000 miles later i cracked the case well the bell from about 4 inches from the starter by the cover up and around. Its got a warranty so not to mad about it but should i just slam a new one in it or should i try something new??
1981 K-5 Blazer 2wd
1985 C-10 Short step
1988 C-10 Suburban
rigon4 is offline   Reply With Quote
Old 05-25-2009, 01:18 PM   #2
Wild83C10
Wild83C10's Avatar
Re: what to do about trans???
I think you need to determine why the trans cracked before you put in another one. Otherwise it could happen again.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 05-25-2009, 05:35 PM   #3
rigon4
rigon4's Avatar
well my trany guy seems to think there was a crack in the case. and he was making fun of me because i had to get the reman and not rebuild the one that came out of the truck. All looks good under the truck so i have to think there was a hair line crack that got missed by me and the factory.
1981 K-5 Blazer 2wd
1988 C-10 Suburban
Old 05-26-2009, 04:46 PM   #4
rigon4
rigon4's Avatar
ok so bad news for now i will know tomorrow if it covered because i put it in my self. so what do you think of j.w. ultra bell bellhousing if its a no go?
1981 K-5 Blazer 2wd
1988 C-10 Suburban
Old 05-26-2009, 06:03 PM   #5
70rs/ss
70rs/ss's Avatar
An ultra bell/scatter shield is an excellent piece of preventative hardware, ask Don Garlits. You are real lucky that thing didn't come apart in a bad way!! You can have the guts of the th400 w/cracked bell put into another case, won't be free, but should be cheaper than buying a complete new 400??
70rs/ss is offline   Reply With Quote
Old 05-28-2009, 09:53 AM   #6
crossy
Oh,you can't buy that new
crossy's Avatar
BOY, does this sound familiar. (cost me a $1000 tranny)let me guess. is the truck lowered?? especially the back? crossy
"been there, done that, ruined the T-shirt".
2007 LBZ GMC Sierra, ECSB
2006 LM7 RCSB Silverado
98 Vortec project.
94,3500,6.5L 4L80
81 SWB GMC POS finally gone
73 Pinto, stock, w/CragarSS's-eww
84,C10 SWB-Yella,stock
86 K10 SWB-Red, hopped up 305,4/S
LOTS of Cummins trucks.
crossy is offline   Reply With Quote
Old 05-28-2009, 10:18 AM   #7
rigon4
rigon4's Avatar
no stock stance and drive shaft is good
1981 K-5 Blazer 2wd
1988 C-10 Suburban
Old 05-28-2009, 11:01 AM   #8
crossy
crossy's Avatar
OK, but i would have the pinion angle checked and make sure the driveshaft yoke has ample 'slide in' distance. i found mine had this tranny history after i broke the case. Due to PO being a butcher. I never got over it due to the work now involved. good luck. crossy
98 Vortec project.
94,3500,6.5L 4L80
Old 05-28-2009, 11:11 AM   #9
cdowns
cdowns's Avatar
hotrodders and racers have been using torque straps to keep an engine in place and prevent failures since b4 WW2
Old 05-28-2009, 02:33 PM   #10
rigon4
rigon4's Avatar
Crossy all that is good I checked it when i got it because of the PO going thought 3 transmissions in 10k miles(he was putting bolt on yoke th400s in it with a one piece drive shaft) Thats why i think there was a hair line crack in it
1981 K-5 Blazer 2wd
1988 C-10 Suburban
Old 05-28-2009, 08:14 PM   #11
scatesracing
Machinist
scatesracing's Avatar
I had th400 do the same thing You could see where it had been cracked for a long time and the the fresh break.... Might just be a th400 thing... or maybe one to many reverse to drive under full throttle i dont know... a friend off mine that worked in a tranny shop said he had seen it before in hardcore 4X4s a few times... I dont think its anything to worry about.... just one of those things
scatesracing is offline   Reply With Quote
Old 05-29-2009, 07:57 AM   #12
djracer
djracer's Avatar
put the ultra bell on it.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 05-29-2009, 09:04 AM   #13
rigon4
rigon4's Avatar
the guy that owns the parts store was going to call and he is playing phone tag with them but he said he will know today
1981 K-5 Blazer 2wd
1988 C-10 Suburban
