Old 05-28-2009, 05:22 PM   #1
kissingbug1978
Curb weight?
Anybody know the curb weight of a 66 short step? I'm being moved to Alaska, and I'm taking my 66 step side with me. Just wandering how much of a load my Ford(yea I said it) will have to endure.
kissingbug1978 is offline   Reply With Quote
Old 05-28-2009, 05:45 PM   #2
BMSJaX
BMSJaX's Avatar
Re: Curb weight?
I think the little metal plate in my '64 Long Fleet said 4000 or 4500 lbs its covered now so I cant see for sure... and I think that was gross vehicle weight
1964 Chevy C10 a.k.a. Julie Ann
H.E.I. cause its better to be pointless
BMSJaX is offline   Reply With Quote
Old 05-29-2009, 03:03 PM   #3
BMSJaX
BMSJaX's Avatar
Re: Curb weight?
No one seems to know so here's my best researched guess
4500lbs GVWR
-1000lbs bed can hold
-100lbs for 16 gallons of gas
-500lbs for max weight of 2 occupants
= 2900lbs curb weight
4000lbs GVWR
= 2400lbs curb weight
So looks between 2400 and 2900 lbs
Gives you 360-435lbs tongue weight I believe
Hope this helps
Old 05-29-2009, 03:20 PM   #4
joe231
joe231's Avatar
Re: Curb weight?
I believe Tony (LILRED66) has the info...but I haven't seen him on in some time...
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 05-29-2009, 04:35 PM   #5
rickf
rickf's Avatar
Re: Curb weight?
4500lbs GVWR
4000lbs GVWR
Hope this helps
That calc looks a little light to me.
I would think my 64 C10 short/step in on par with the 66.
I used to haul my own trash and so got regularly weighed going in and out.
Going out, empty bed and just me, the weight was very consistent at 3900 lbs. Take my 200-250 lbs out and ya get 3600-3700 lbs.
I'm not sure, but I would think separating the passengers from the bed payload in that calc is incorrect. The "half ton" capacity is what ever goes in the truck that is not the truck itself, so passengers and payload together are your half ton.
rickf is offline   Reply With Quote
Old 05-29-2009, 07:48 PM   #6
BMSJaX
BMSJaX's Avatar
Re: Curb weight?
Alright just took my kick panel off and looked; GVWR 5000
5000lbs GVWR
-1000lbs bed load
-500lbs 2 persons
= 3400lbs curb weight
or 3900lbs if you don't separate cab weight from bed weight
hahaha, Probably shoulda looked yesterday....
Old 05-29-2009, 10:29 PM   #7
scotts62
One day...
scotts62's Avatar
Re: Curb weight?
My factory tag says 5200, for a short step.
Scott
93 crew cab build
Project 62
Old 05-29-2009, 10:52 PM   #8
bubba327
HOW long until spring??
bubba327's Avatar
Re: Curb weight?
Texas should have a livestock feedlot or dairy with a scale somewhere . Find a weigh station with a scale. Just pull it on and weigh it so you don't overload the Ford or your trailer.It is good to know how much you are pulling. It is a long way from Texas to Alaska. Good luck
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
