Old 05-29-2009, 05:03 PM   #1
into69z
"brand new second-hand"
into69z's Avatar
how do you replace door pins?
I need to replace the door pin on the drivers side of my truick. I know someone has done this and knows the best and easy way to get it done. Do I have to take the door off or the fender? is there a way to push the pin out just with the door open? thanks
Steve
69 3/4t custom camper
tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c
67 Camaro
96 Impala ss-sold
04 hybrid Honda-saving gas for the blue truck!:
b69:
into69z is offline   Reply With Quote
Old 05-29-2009, 05:29 PM   #2
LONGHAIR
Re: how do you replace door pins?
You are far better of to just remove the door than to try to fight it. The one with the "check" (spring loaded mechanism) will absolutely have to come off of the truck to get the pin out. In most of the older vehicles the pin will not physically come out of the upper hinge while mounted because it would hit something...fender, door, etc.
Be aware that you will have to replace the bushings too. They are soft (bronze) so they wear-out before the pins start to wear.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 05-29-2009, 05:36 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Once removed, you might be able to hammer the old ones out, but you really should put some heat into it with a torch. Once you do that, the pins will release much easier and you won't have to get medieval on them with the hammer.
The pins and bushings will run you 10 bucks per side.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 05-29-2009, 07:12 PM   #4
leddzepp
Moderator
leddzepp's Avatar
Remove hinges from the truck.
Soak with PB blaster.
Hit them with a torch after they have soaked for a day.
Soak with PB again for a day.
Put the hinge in a vice, hit it with torch, and then hit it ONCE with a 5lb sledgehammer as hard as you can to drive the pin out. If you hit it too many times, it will mushroom and you will never get it out, short of cutting it with a dremel tool....which takes forever.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 05-29-2009, 08:42 PM   #5
into69z
into69z's Avatar
once again, Thanks for your help! sounds like a two day job to do it right.
Steve
67 Camaro
96 Impala ss-sold
b69:
Old 05-29-2009, 08:50 PM   #6
Tx Firefighter
I can do a full rebuild and powdercoat job on a set in about 3 hours. That includes cooking time for the powdercoat. It's not that big of a job.
Old 05-29-2009, 10:16 PM   #7
Jim_PA
They are a real ***** to do.
Jim_PA is offline   Reply With Quote
Old 05-29-2009, 11:56 PM   #8
El Jay
Gone to greener pastures
Kevin beat me to it.
I was going to suggest just swapping out your old hinges with rebuilts.
If you want to add powdercoating; he's your "go to" guy.
He did some stuff for me & I couldn't be happier.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
