Old 05-27-2009, 07:56 PM   #1
ericpost
ericpost's Avatar
Newly Lifted rig, What Shocks?
I lifted my truck somewhere a bit north of 6"
REAR: DIY 4" shackle flip, Reverse the mounts, 56" springs with 4" lift, removed the helper spring...
FRONT: DIY FGB52's mounts, Moved stock 52" rear springs to the front, slipped the helper spring from the rear in to level it up.... waiting until rears sag a bit, then I'll slip the helper spring back out.
I also did 1 ton axles.
Long story short nothing I can purchase directly out of a catelog with any confidence.
I measured the Front and Rear shock mount lengths and got:
Front 20.5" c to c
Rear 26.5" c to c
Any ideas on what shocks/part numbers fit?
Oh and here is a poser shot, no front brake lines, no front shaft, and no fender trimming yet... Just got her rolled out of the barn had 3/4" of clearence to spare! I'm 6' 4" tall...
72 GMC Jimmy, 350, sm465 np205 (getting a face lift)
64 Nova SS, 327 SC & gassed, TH350. (blowed it up)
84 HD FX frame,80 FL tins, evo with 85hp/90tq (wifes bike)
96 HD FatBoy evo with 102hp/100tq (mine!)
KEEP NOTHING STOCK!
ericpost is offline   Reply With Quote
Old 05-27-2009, 08:09 PM   #2
Re: Newly Lifted rig, What Shocks?
NICE!!! I see disc brakes on the rear.Can`t you give the lengths and lift info to get the right shocks?I bet Superlift could help you out.They are owned by Heckothorn who have made off road shocks forever.And,Superlift builds all kinds of custom lift kits.
Old 05-27-2009, 08:15 PM   #3
ericpost
ericpost's Avatar
Yep got the disc brake brakets from someone on Pirate for 45 bucks shipped to my door! I think the whole conversion was under $175 (took the orig front calipers and moved them to the rear!)
KEEP NOTHING STOCK!
Old 05-27-2009, 10:03 PM   #4
84 400
Sb 400 club
84 400's Avatar
sorry I cna't help much but cool to see more local people around here!
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 05-28-2009, 09:48 AM   #5
Yukon Jack
Yukon Jack's Avatar
Your K5 looks really good with great upgrades. Am I correct in assuming with it built the way you have, you will be taking it offroad? If that is correct, I'd recommend you spend some time measuring with the suspension fully compressed and flexed so you get a more accurate idea of what you need from your shocks. Hate to have the shocks limit your flex and end up damaging your shocks.
With that being said, for my truck that doesn't get beat on, what I did was took my center to center measurement like you have, than I went to Rancho's site and they have a .pdf file that lists their shocks and respective specs.
If you were looking at their RS5000 series, the RS5112 has the correct ends and compressed it measures 16" and extended it measures 26.250" with total travel of 10.250. That shock would probably be good for the front axle.
For the rear axle, the RS5134 has the correct ends and compressed it measures 19" and extended it measures 32.625" with total travel of 13.625.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 05-28-2009, 10:18 AM   #6
Burt4x4
Burt4x4's Avatar
YJ busten out the numbers! yyyyyyyyyyyeeeeeeeehhhhhaaaaaaaa
Nice rig post more pics when you can.
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 05-30-2009, 09:07 AM   #7
ericpost
ericpost's Avatar
Interesting.
So using those numbers:
FRONT: 4.5" of compress and 5.5" of extend travel
REAR: 7.5 of compress and 5.5 of extend travel
I do have shorter springs in the front so I get the limited travel there but the rear seems unbalanced.
Has anyone measured compress/extend travel with a 52/56 spring swap? I do plan to wheel the rig so I expect to flex it. I have her limping at this point so I really can't get her crossed up yet... I did just get my front brake lines in from inline tube... sweet!
I also forgot to mention I'm installing crossover with high steer.... I have another post on that topic but if anyone knows where I can get a 2wd sector shaft to replace my 4wd shaft please let me know... I have 2 brand new 4wd steering boxes and don't want to buy a 2wd drive box if I don't have too.
KEEP NOTHING STOCK!
Old 05-30-2009, 09:20 AM   #8
dammitmitchell
the pollock
dammitmitchell's Avatar
nice rig!
crap!
call skyjacker directly they will be able to tell you what youll need
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
