Old 05-30-2009, 11:13 AM   #1
lks dcvn
lks dcvn's Avatar
mini starter installed...loud noise now
Just had my mechanic install my exhaust and Skip White mini starter...
Good news - 2.5" exhaust sounds great and looks awesome
Bad news - mini starter is loud as can be - doesn't sound right to me
How are they supposed to sound?
It sounds like it is holding the crank a bit too long...
lks dcvn is offline   Reply With Quote
Old 05-30-2009, 11:17 AM   #2
mr48chev
mr48chev's Avatar
Re: mini starter installed...loud noise now
Is it noise from the reduction gears or noise from the starter and ring gear?
I think those are universally noisy no matter who sells them.
Old 05-30-2009, 11:18 AM   #3
my67chevytruck
Under Construction
my67chevytruck's Avatar
any shims required?
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 05-30-2009, 11:36 AM   #4
70c10
67-72 Addict!
70c10's Avatar
We need details and pics of exhaust!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 05-30-2009, 11:56 AM   #5
cdowns
cdowns's Avatar
ministarters should b shimmed for the same 1/8clearance as regular starters
Old 05-30-2009, 12:11 PM   #6
Arad68
Trucks N Tranzams
Arad68's Avatar
How do you know this wasn't done? While your advice is appreciated, you sometimes communicate advisarily. Not everyone is a dumb*%#.
Aftermarket ministarters are universaly loud or sound like the gears or grinding or schreeching. Look to see if the starting gear is engaging fully on the flywheel or flexplate.
Every mini starter I've put on my trucks (3 times) has been loud or the gear just doesn't extend far enough.
Cdowns, yes I shimmed everyone of them to 1/8th of an inch
Don
'68 Chevy LB 383 TH400/GV/373 posi
'56 Chevy 4WD SWB
'64 Chevy short stepside
'79 Trans Am 455/TH2004R/12blt/4whldisc
95 Kia (Wifes car)
2002 S-10 extended cab pickup
"God punishes small sins immediately"
Arad68 is offline   Reply With Quote
Old 05-30-2009, 12:30 PM   #7
IAFF2407
IAFF2407's Avatar
Arad68, you get up on the wrong side of bed this morning? easy boy.
1972 GMC Sierra
1972 GMC Super Custom Suburban
IAFF2407 is offline   Reply With Quote
Old 05-30-2009, 12:33 PM   #8
Arad68
Trucks N Tranzams
Arad68's Avatar
Thanks,
My comments were a little harsh. Simmering down now...
Don
'56 Chevy 4WD SWB
95 Kia (Wifes car)
Old 05-30-2009, 02:59 PM   #9
cdowns
cdowns's Avatar
yeah if you had read the COMPLETE THREAD you would've seen i answered a question that was asked plain and simple
dimwit
Old 05-30-2009, 03:47 PM   #10
lks dcvn
lks dcvn's Avatar
OK. took it back and they added a few more shims...sounds a lot better now. quick start.
now when driving I get a 'ting ting' metal on metal sound when you hit the gas. I don't get that noise in park only when driving...
any ideas?
sorry for the crappy format - I am typing on my work phone.
Old 05-30-2009, 04:01 PM   #11
jgreene0717
Jason
jgreene0717's Avatar
That sounds like you are having a pre ignition ping. Check your total timing with vacuum advance disconnected. You may also try to disconnect vacuum advance and take it for a spin and see if it still does it. If it does not you need a adjustable vacuum advance.
jgreene0717 is offline   Reply With Quote
Old 05-30-2009, 04:52 PM   #12
Arad68
Trucks N Tranzams
Arad68's Avatar
dimwit
Control yourself buddy or at least try
Don
'56 Chevy 4WD SWB
95 Kia (Wifes car)
Old 05-31-2009, 10:35 AM   #13
lks dcvn
lks dcvn's Avatar
I guess I should clarify - here are the symptoms
When I first heard the truck start = loud noise - no metal banging noise when hitting the gas
Took it back - they shimmed it - sounds more normal starting - when driving the truck on the road metal banging noise is present when hitting the accelerator...when revving the motor in park - no metal banging noise.
Took it back again - they added another shim - no metal noise when revving in park - when driving metal banging noise is present...
It sounds like a hammer hitting metal - like it might be the flexplate banging on something.
I went out and got some pix this morning - I can see debris on the starter - so it looks like the starter is hitting the flexplate when driving...great. I might clean it off and go for a spin and see if it comes back - that will really let me know - if it is still happening or from when they didn't have the starter shimmed right the first time.
I also noted a new oil leak from the spark plug area - tell me this is an easy fix...
Old 05-31-2009, 10:39 AM   #14
dan42
dan42's Avatar
Uh, that oil leak looks a little milky...not good.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 05-31-2009, 10:40 AM   #15
lks dcvn
lks dcvn's Avatar
I will also add some pix of the new exhaust system. Old setup was manifold to a spare set of exhaust with mufflers that just dangled under the truck...did the job - but didn't sound that great...
New system:
2.5" center dump manifolds
2.5" aluminized exhaust tube
Flowsound 2.5" mufflers
Old 05-31-2009, 11:15 AM   #16
lks dcvn
lks dcvn's Avatar
milky oil - nope - might be from the GUNK engine cleaner that was still on the block.
I had to find out where the leak was coming from so I doused the block so I could find the source...
don't scare me like that..
My next question - if it turns out to be the flexplate - my trans guy is 40 miles away - I doubt it would be safe to drive it that far to have it looked at right...I might be screwed here as I don't have a trailer to get it there - I would need to drive it.
Also - why would the banging happen only in D and not at idle or revving in park?
Old 05-31-2009, 11:31 AM   #17
Arad68
Trucks N Tranzams
Arad68's Avatar
Thats a good looking truck.
Inspect the flexplate for scuff marks where it may have contacted the starter while you were driving. You can do this with a good size screwdriver to turn the flexplate. Somtimes you may be able turn it with your hands and a good pair of gloves.
There should be at least 1/16th of an inch between the starter gear and the flexplate. If there has been contact, the flexplate or ring gear may be warped or not properly installed.
Observe the flexplate with the engine running. This would be the easiest way to see.
Don't get under the truck while it's running.
If it shows untrueness, the ring gear is bent or not properly installed. There maybe corrosion or dirt/grease build up on the crankshaft flange.
Clean off the oil leakage to observe for any obvious defects such as cracks. This will also allow for a clear look were the leak is coming from after it has leaked again.
Dan42 has a good eye, it looks kind of "milky" indicating the presense of water in the leak.
Don
'56 Chevy 4WD SWB
95 Kia (Wifes car)
Old 05-31-2009, 12:12 PM   #18
lks dcvn
lks dcvn's Avatar
Flexplate has some damage on it - but not sure if that was before they shimmed it correctly...
After looking at another post - some people have taken a bit off the end of the drive gear to alleviate the issue...
http://www.trifive.com/forums/showthread.php?t=25045
Another post I found said that the flexplate was cupped (it was round but cupped so the teeth were too close for the new starter)
http://www.jalopyjournal.com/forum/s...d.php?t=273647
I did find an easy way to swap the flexplate w/o having to drop the complete trans...
"Hi,the easy way to change the flex plate is,get some 4 inch long bolts,remove all the trans to block bolts and replace the bottom 2 bolts with the long bolts,remove drive shaft,and shifter,slide trans back on long bolts ,you probably wont have enough room to slide trans all the way back.,,after changing the plate, slide trans forward and rebolt." - taken from this link:
http://www.hotrodders.com/forum/mini...te-155405.html
Looks like I have some work ahead of me...
This thing will never be done and ready to hand off to my Dad...
Old 05-31-2009, 12:40 PM   #19
big mike71
big mike71's Avatar
IMO you owe cdowns an apology not another crack, he answered a question then you slam him and act like he's an a$$hole for being mad about it.
big mike71 is offline   Reply With Quote
Old 05-31-2009, 03:03 PM   #20
Arad68
Trucks N Tranzams
Arad68's Avatar
Thanks Mike,
I appreiciate you pointing out my oversight.
Cdowns, you have my apology.
The crack was in response to the dimwit remark.
Don
'56 Chevy 4WD SWB
95 Kia (Wifes car)
