![]() Join Date: Oct 2008
Brake booster/Master cyclinder suggestion
Alright let me give you a brief summary, I have:
-DropMember -454 BB -Tall Valve covers -I have a cam with a choppy/thumping idle so probably wont give no vaccum lobe center: 107 Intake Center: 102 So the DM raised my engine, and then I have the tall valve covers due to the roller rockers, which makes the installation quite impossible. I think that even if I had the 7inch booster, I would not be able to remove my valve covers. CPP also mentioned that with a radical cam I would only have about 2 pumps with a canister. I call CPP for an opinion and they recommended thier Hydroboost -It cost about $700 (wow!) Is thier an alternative to this, I have heard of electric brakes but Im not to sure. What do you guys recommed?
1968 Chevy Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=321717 1959 Chevy Apache 3100 SWB Big Window http://67-72chevytrucks.com/vboard/s...d.php?t=597069 |
dazed and confused
Re: Brake booster/Master cyclinder suggestion
i have seen people run manual disc brakes and be fine.
members met: redbaron69, billsbowtie,nc67 |
Hydro boost, works great.
You can pull hydroboost units from 80s 1 ton chevy trucks and astro vans. It can be done for a couple of hundred bucks. Check out Yukon Jack's install thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=223491
Tony Johnson -- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer -- |
its all about the +6 inches
nothing wrong with manual brakes, they came like that in a few trillion vehicles over the years.
