Old 05-07-2009, 05:29 PM   #1
swyfor5
swyfor5's Avatar
Dana 20 or Dana 205?
I'm sure this has been done before, but it was brought to my attention that I might have a Dana 20 in my K5. Was in truck when bought it, and always thought it was a Dana 205. Here's a pic, any pros-cons?
swyfor5 is offline   Reply With Quote
Old 05-07-2009, 09:49 PM   #2
swyfor5
swyfor5's Avatar
Re: Dana 20 or Dana 205?
Sorry guy's, me bad. I meant Dana 20 vs NP205 transfer case. Just trying to identify my t case. Never really heard of the dana 20, but want to know what I've got under there! Any feedback on the diff between the 20 and the 205? What I have found out is they used both in the first gen. K5's, right? Is the np205 better than the dana 20? Whatever it is thats in there has worked fine so far, but with the new build coming on I want to do it right! I just assumed it was a np205, as it sits behind a sm465 4 speed manual. I have never checked the serial #'s, or maybe I would have thought about it before!
Old 05-07-2009, 10:32 PM   #3
turp mcspray
turp mcspray's Avatar
Hi, I remember seeing some info on this some time ago.
All automatics (th350), and I THINK the 4speeds,got the 205. And the 3speed manuals got the Dana 20. I think the base v8 enginetrans combo was 307/3spd manual. I have seen lots of plainjane blazer/jimmys with this setup. I will try to dig up my dealer brochure and verify this info. Also think dana20 had a lower low range. The 205 is the stronger of the bunch.
Hope this helps a little.
turp mcspray is offline   Reply With Quote
Old 05-08-2009, 06:01 AM   #4
Blazer1970
Blazer1970's Avatar
Yes, that is a Dana 20 in your truck. The 205 is a stronger case, but the Dana 20 is strong enough for the application. I switched over to a 465/205 in mine since I found a donor truck with all of the parts I needed.
Blazer1970 is offline   Reply With Quote
Old 05-08-2009, 07:41 PM   #5
swyfor5
swyfor5's Avatar
Any other opinions? If what I know so far is true, the dana 20 stays till it breaks! Oh, unless I find a sweet deal on a np205! Anybody seen a pto winch setup on one of these dana 20's? Pic's?
Old 05-09-2009, 08:13 PM   #6
swyfor5
swyfor5's Avatar
Ok, so far I have found that the dana 20 is a good t-case, but not as good as the np205. The 20 can be upgraded w/ lower gear setups, etc. I know the one I have has a few issues, and just want to know if I should rebuild/upgrade or swap?
Old 05-11-2009, 09:57 AM   #7
turp mcspray
I found some info that I had. It says that all 3spd manual got the dana 20. If you ordered the opptional v/8 (350) then you had to also upgrade to a 4spd or th350 all of which came with 205. I see alot of early bronco guys wheel hard with a 20. It's kind of like having a 10bolt rear end in your chevy car instead of a 12bolt. It will probably work fine but isn't as sexy as having the other. HaHa!
Old 05-11-2009, 03:46 PM   #8
swyfor5
swyfor5's Avatar
Trying to remember when I ran my Vin #, it showed K5 came with V8 motor, and manual trans. I don't know, but it doesn't appear that the steering column and trans/tcase "hump" have been changed. That would rule out a 3 speed trans being original. Like I said I don't know, as I bought this K5 used, from a dealer in Salt Lake City, Utah back in 1981.
Old 05-11-2009, 06:43 PM   #9
Jtrux
I'm a poor spectator
Jtrux's Avatar
For what it's worth, IIRC the first Bigfoot had a Dana 20 in it. Just saying...
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 05-11-2009, 07:32 PM   #10
swyfor5
swyfor5's Avatar
Cool fact! Unless I'm steered different, I'm going with the 20. Kinda because it's already there, and it seems to work fine. Maybe think about upgrading to lower gear setup, etc. I just want to know, cause it's all coming out eventually for the resto!
Old 05-12-2009, 06:02 AM   #11
Blazer1970
Blazer1970's Avatar
Some of these Blazers came with a 465 mated to a Dana 20. That is what the OP in this thread has.
Old 05-12-2009, 10:03 AM   #12
Yukon Jack
Yukon Jack's Avatar
Yep, my 1970 K5 has an SM465 and originally had the Dana 20.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 05-12-2009, 06:27 PM   #13
swyfor5
swyfor5's Avatar
Yukon, why did you swap out the 20? Any problems swapping in a 205? Just asking?
Old 05-12-2009, 08:58 PM   #14
Yukon Jack
Yukon Jack's Avatar
Prior owner broke it, probably doing something really stupid based upon the fact that once I finally got the vehicle ready to fire up, I found it also had a bent rod. Transfer case was out when I bought the vehicle and just made sense to step up to the NP205 when I replaced it.
Old 05-13-2009, 03:39 PM   #15
swyfor5
swyfor5's Avatar
Remember what broke on it? Just "looking" for the weak link!
Old 05-14-2009, 03:33 PM   #16
swyfor5
swyfor5's Avatar
Anybody know the real story on how dana 20's ended up in some 1st. gens? Really thinking about dumping it and swapping in a np205. Am probably going to have the 20 torn down and gone through for the resto. But if I'm going that far I might as well upgrade to the 205! Decisions, decisions, decisions!
Old 05-15-2009, 06:18 AM   #17
Blazer1970
Blazer1970's Avatar
The real story?? That is what GM decided to use. The Dana 20 was used in both the Bronco and the Scout at the time so GM probably thought it would work well in their "bobtail" also.
If I were you, I would look for a 205 also. Just a much better set-up in every respect.
Old 05-15-2009, 01:52 PM   #18
Yukon Jack
Yukon Jack's Avatar
No idea what he broke, it was not with the vehicle when I bought it.
Old 05-15-2009, 06:20 PM   #19
swyfor5
swyfor5's Avatar
Well, it looks like it's time to upgrade to the np205! Why put any money in the 20, when I'm going to resto the K5 the "right" way. Gotta love this forum for good info! Any major changes I have to do to go with the np205, or is it a direct bolt in? Plan on some new t-case mounts, and the 1 ton thing , anything else?
Old 05-17-2009, 10:29 PM   #20
69TowRig
Even if the truck had a 3-speed it would have the high hump transmission tunnel since it is a 4x4. Mine is the original 307/3-spd/Dana20.
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
Old 05-18-2009, 01:41 AM   #21
Beelzeburb
Devil's in the Details
Beelzeburb's Avatar
I've still got the whole 307/3 speed/D20 laying around from my Blazer and I can't seem to find soemone locally who'll pay for it.
Anyone know definitively which ratio the Blazer Dana 20 had? After a quick search, most sources state it has a 2.00:1 low range, while the NP205 is a 1.96:1. Doesn't seem like there would be much gain in simply switching t-cases because either one is a strong, all gear driven case.
Of course, if you were going with some sort of a doubler I could see the trouble.
'70 K10 Suburban - TBI 454, 4L80E, NP241C, Dana 60 & 44 - The 10+ Year Project Thread
Datsun 240Z, 510 2 door and an old Honda motorcycle
Beelzeburb is offline   Reply With Quote
Old 05-29-2009, 07:37 PM   #22
swyfor5
swyfor5's Avatar
Ok, enough is enough! I think I have decided to go with the np205. My next question is should I look for a used one for a possible rebuild, or would it be better to go with a aftermarket t-case? Really trying to save the $ starting out, but want to do it only once!
Old 06-03-2009, 09:18 PM   #23
swyfor5
swyfor5's Avatar
Dug out my old Clymer super shop manual for trucks. In the transfer case chapter it states- it provides removal, installation, and overhaul procedures for the Dana 20 and New Process 203,205,and 208 t-cases. Say's the dana 20 t-case is a manual shift, 2 speed t-case used in 1970-1975 vehicles. Goes on to say the New Process 205 t-case is a manual shift, 2 speed, part-time t-case used in 1970-on models. Hmmm! Oh, by the way, the Clymer manual covers from 1970-1985!
Old 06-03-2009, 11:38 PM   #24
Beelzeburb
Beelzeburb's Avatar
Yep, they were made through 1993 AFAIK. Start scouring the junkyards and looking for that idler shaft cover.
Check out this ID guide:
http://offroaddesign.com/catalog/Tra...ID%20Guide.htm
Old 06-04-2009, 03:25 PM   #25
swyfor5
swyfor5's Avatar
Yea, it's like I need to flip a coin or something. I could run the 20 and see how it holds up, look for a used 205, or maybe get the lomax setup. I plan on going to 1 ton setup next, and want to do it right.
