Old 06-04-2009, 12:12 AM   #1
meangreen68
you gotta be kiddin!
meangreen68's Avatar
trans options for 250 6cyl?
Just wondering what you all are running behind the 6 cylinders? Stock or custom set-up. I've got the three on the column, and probably 3.73 gears, and was thinking it would be nice to have overdrive. But gear vendors type equipment is a little expensive. What are the options?
It ain't easy being greasy!
meangreen68 is offline   Reply With Quote
Old 06-04-2009, 12:22 AM   #2
vasquezmrysvll
"the other guy"
vasquezmrysvll's Avatar
Re: trans options for 250 6cyl?
700r4 or 2004r
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE"
vasquezmrysvll is offline   Reply With Quote
Old 06-04-2009, 07:55 AM   #3
72BlckButy
Tot Roddin'
72BlckButy's Avatar
I have heard a lot of people have swapped in a 200R4 without much hassle. Currently behind my 250 I'm running a 2spd powerglide, but have considered the 200R4 swap.
There was a recent thread discussing the install fo a 200R4 on a 6cyl, it was in the 67-72 message board area, that might provide a little more information for your decision.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 06-04-2009, 09:42 AM   #4
tkeduk8r
tkeduk8r's Avatar
2004r definetly... find a good trans out of a heavier wagon, throw a cooler on it, and it will do everything you will need it to for $300 or less...
--Mike
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
Old 06-04-2009, 10:24 AM   #5
meangreen68
Hey thanks for the info...What about manuals? Anybody done a modern manual 5-6 speed. I've wondered about the 5 speeds from a late 80's early 90's 1500. I had one of those for 11 years and worked it hard, and only had to replace the clutches periodically.
thanks again...
Old 06-04-2009, 10:42 AM   #6
WorkinLonghorn
WorkinLonghorn's Avatar
I don't know anything about modern tramsmissions but there was an overdrive manual option for our trucks with a .70 OD which could be used in all forward gears providing 6 different ratios.
I don't know how hard it would be to find one of these.They were an option on 1/2 tons with 4.11 gears. (per the '69 Data Book)
I thought about switching to auto trans as suggested in some of the above posts and decided it was more work and expense than I wanted.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 06-04-2009, 12:44 PM   #7
68 longbed
I'm using a T-5 from a chevy astro van and love it.
68 longbed is offline   Reply With Quote
Old 06-04-2009, 04:05 PM   #8
Shaky
Six in a row makes it go...
Shaky's Avatar
I have a Richmond Gear 5-speed with a 3.07 rear.
My other truck has a 292 with an SM420. I'm probably gonna shell out for the Gear Vendors behind that one.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 06-04-2009, 04:28 PM   #9
caja_larga
I really want a overdrive automatic in my truck. I think the 700r4 would be nice due to the low first gear however Iam worried about the big drop in gear ratios going int 2nd. The 200r4 is more like the 350 with an overdrive. My 350 seems like a lower first gear would help.. does any one have first hand knowage on either?
caja_larga is offline   Reply With Quote
Old 06-04-2009, 05:16 PM   #10
mvfd70
mvfd70's Avatar
NV3500 out of a 90's truck will fit the 250. There's posts on here about just that. I'm planning on putting one on my truck. You will have to do some fab work for the hydraulic clutch though
1978 Chevrolet Silverado 3/4 ton 400 small block.
2000 F-250 Powerstroke
2002 GMC Yukon Denali XL
mvfd70 is offline   Reply With Quote
Old 06-04-2009, 08:05 PM   #11
Botietruck
'71 chevy s.bed/s.side
Botietruck's Avatar
I'm running a 250 with the 3 spd. Saginaw & a Borg Warner overdrive unit.
There is a board member that just might have the complete setup for sale. Check with CG.
STILL PLAYS WITH CARS...AND TRUCKS!!
Parents! Be good to your kids...they get to choose your nursing home!
250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive!
Botietruck is offline   Reply With Quote
Old 06-05-2009, 12:07 AM   #12
XXL
Señor Member
XXL's Avatar
You may want to do some wheel spinning and some math. Most of the 3 speed 250's came with 4.11 gears. If so, a TH350 is going to wind out first gear practically by the end of the driveway, and your top end will be about 65-70 mph before you feel like you're wrapping the engine up too tight. I had this setup and dropped to 3.73 gears and it is much better... I don't feel like my motor is going to explode when I'm driving down the highway at 70.
XXL is offline   Reply With Quote
