#26 | |
Re: 1966 gas tank retro fit under bed
#27 |
60-66 Nut
Thanks for adding that Joe.....good point.....totally forgot about that
#28 |
For the sake of tech dicussion. It seems to me you could put a newer tank and sending unit (0-90 ohm) and wire a 58 ohm resister in parallel. This would make your guage "see" 35.27 ohms full instead of 90.
Someone has to have done this........did it work? A Bronco tank might make a good swap for these trucks too. The filler comes out the side. 25.5 Gal and 33 Gal available Swiped from Jeffs bronco graveyard |
#29 |
Wide Eyed User
This was the thread for my 62. but the 63 up frames are even easier.
http://67-72chevytrucks.com/vboard/s...d.php?t=320376 ![]()
1962 Chevy P/U SB Fleetside 350/350 2.5/5 static drop My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=294723 Final (as final can be ![]() |
#30 | |
![]() ![]() Last edited by joe231; 02-06-2009 at 03:23 PM. |
#31 |
how about one of them 31 gallon blazer tanks from jcwhitney for $147. what else would i need?
#32 | |
I am going to try it with a Bronco tank. I will start a new thread when I do it. |
#33 |
Junior Member
As far as dimensions and making it fit, I found a lot of different options in this catalog with dimensions. I am just never sure if their dimensions are from the outside edge of the flange or from the sides of the tank.
http://www.quantaproducts.com/departments.asp?dept=1 |
#34 | |
cool, can't wait ![]()
![]() ![]() Last edited by joe231; 02-06-2009 at 07:01 PM. |
#35 | |
I will put a 1 ohm resistor in series with the sender/58 ohm and elimante the possibility of ever going 0. I think all the parts are less than $1. |
#36 |
actually that won't work, if the sender went to zero ohms then you would have a 58 ohm and a 1 ohm in series for a total of 59 ohms...
![]() ![]() Last edited by joe231; 02-08-2009 at 12:31 AM. |
#37 | |
#38 |
#39 |
I picked up a tank from a blazer, now I am just wondering how people have plumbed it and what they did for fuel filler etc. I have found a lot w/ the fleetsides, but I have a step.
#40 |
///Relaxed Atmosphere
here is what i have done on my 64. go thte tank a few years back when So Cal Speed Shop had a store here in the Houstoin area. The tank is from Tanks Inc if I am not mistaken. Should have the bed mount back on the truck in the next few weeks before we tear back down for paint.
72 Suburban 64 Chevy short fleet 04 Chevy Colorado Sport Reg Cab 2012 Chevy Avalanche 2003 Chevy S10 Blazer Xtreme http://www.hubgarage.com/mygarage/RA_Jeff 64 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=295915 |
#41 |
![]() Join Date: Sep 2006
If you get the 67-72 blazer tank kit you can order it with a 0-30 ohm sender or the 0-90. It fits in the frame rails so no trimming or welding and it is 20 gals. Here are some pictures of it in my frame. http://s49.photobucket.com/albums/f2...t=000_0346.jpg
http://s49.photobucket.com/albums/f2...t=000_0345.jpg Sorry they are too big to post in the thread.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
#42 |
and a few others
here ya go....
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
#43 |
i need a inexpensive tank to fit my '63 carryall...any suggestions??? working on tight budget,, any help would be appreciated...
