Old 05-23-2009, 06:09 AM   #151
heidesign
Re: 1969 Chevy Stepside Restoration/Build up
Sure turned out nice. You should be proud.
Great looking truck.
heidesign is offline   Reply With Quote
Old 05-23-2009, 03:53 PM   #152
matthew20061
69' Chevy Stepside
matthew20061's Avatar
Thanks, I never thought it would come out this good!
-Matthew
-69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead"
- Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread
-1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed
-1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting
-2003' Chevy Silverado SS AWD 6.0L! - Daily Driver
matthew20061 is offline   Reply With Quote
Old 05-23-2009, 04:03 PM   #153
matthew20061
69' Chevy Stepside
Since it got really dusty from being in the garage such a long time it was time to give it it's first wash! Luckily it didn't leak any water, except for around the top of the drivers side door a bit because its out from the top of the cab slightly.
-Matthew
Old 05-23-2009, 04:22 PM   #154
killer71
killer71's Avatar
cleaned of nicely!
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 05-23-2009, 10:37 PM   #155
mas09ts
mas09ts's Avatar
that thing looks great matt
Mitch
22yrs. Young
1970 GMC Short-Step 350/TH350 Combo. . . . Sold Dec 2011
Current Project 68 Gmc "Second Chance"
Go to my 68 GMC Shorty Rebuild Thread
http://67-72chevytrucks.com/vboard/s...39#post6341739
mas09ts is offline   Reply With Quote
Old 05-23-2009, 11:34 PM   #156
matthew20061
69' Chevy Stepside
Originally Posted by killer71 View Post
cleaned of nicely!
Thanks!
I still have a lot of lose ends to tie up, like the computer thinks its in drive all the time, only the front brakes work, and a power steering fluid leak. Also I have to get the crank position sensor relearned because it has a code P1336. The scanner at the shop I took it to won't initiate the relearn procedure with the computer thinking its in drive all the time. Today I decided to investigate the problem and found that the wires to the neutral saftey switch were never connected to the computer so I have to get them hooked up (whoops).
-Matthew
Old 05-29-2009, 03:50 AM   #157
matthew20061
69' Chevy Stepside
Forgot to post this. I took the 69' to a car show on Memorial Day! Everyone was really interested in the engine and how it was installed and such. Anyway here's some pics.
--Also does anyone have any Ideas on why I can't keep my front brakes working??? I converted to front discs, power brakes and a new CPP proportioning valve for the setup. I bent up new lines from the master cyl to the proportioning valve I have the one going from the rear of the cyl to the front brakes and from the front of the cyl to the rear brakes. I started off by bleeding the rear brakes, got those working. Then moved to the front passenger side wheel and bled that one and then to the drivers side wheel. Then I discovered that the shuttle valve moved forward and cut off the front brakes. So i reset it and bled and bled and bled to get any air out. Now when I press the brakes it feels normal then there's a sort of a click or pop and then the fronts kick in and start working. While driving the shuttle valve seems like it moves forward or something and then I only have rears if I reset it I get fronts for a while then it moves forward again! Sorry for the long message....
-Matthew
Old 06-05-2009, 05:06 AM   #158
basketcase
basketcase's Avatar
The front of the master cylinder goes through the front of the proportioning valve and then to the front brakes. The rear goes to the rear. I looked through your pictures until I found one that showed the brake lines and it looks to me like you have them flipped.
I also noticed that you mounted your CPP prop valve low on the firewall. I'm not sure why but if you would have used the bracket to mount it on the mc mounting bolt the lines would have fell in place. I used a slightly different booster and mc so I had to bend up a different rear mc to valve line than was supplied with the kit but the front lines were perfect as is.
Here's mine using a CPP prop valve.
Tom
basketcase is offline   Reply With Quote
Old 06-05-2009, 02:49 PM   #159
matthew20061
69' Chevy Stepside
Tom
Thanks for the reply! Your absolutely right I bent the lines backward. I guess the reason I did this is because on my 72 GMC 3/4 ton thats the way the lines go must be different for 1/2 tons because I looked at another 1/2 ton stepside today and it had the lines like yours so I must need to replumb those lines. Thanks!
-Matthew
Old 06-05-2009, 05:11 PM   #160
cerebus
Absolutely beautiful truck! Love the color. Congrats!
-- Tall, Dark and Handsome... Or so my mother says
-- There is no fate, but the fate we make.
cerebus is offline   Reply With Quote
Old 06-05-2009, 06:39 PM   #161
matthew20061
69' Chevy Stepside
Thanks!
-Matthew
Old 06-05-2009, 10:06 PM   #162
matthew20061
69' Chevy Stepside
Well I installed the bed wood and strips today temporarily until I get a fuel pressure regulator for the inline fuel pump setup that I need to install. But for the moment its complete until I have to install that pump.
I ran the vent line for the gas tank up the stake pocket but I need a filter or something for the end of it so water doesn't get down it....
Couldn't put in some bolts because of the gas tank and filler neck.
-Matthew
Old 06-05-2009, 10:20 PM   #163
seldomseen65
spirit rider66
seldomseen65's Avatar
Location: pahrump, nevada, in the bowels of the Mojave desert
Originally Posted by matthew20061 View Post
Thanks!
Hi Matt;, just going to put my two cents worth of praise ,,cool looking truck you did an awesome job on it and you did it in Alaska, "WOW" it couldn't have been any harder, but you did it Matt, love that color, matches your hair, lol lol
i went through the whole thread and how did you get the bed done,liked what you did with the seats and the center consul ,, cool dude,, and to finish ,i'm going to say how jealous i am, your work on the truck could be your future, keep up the nice work . only i wish i was 30 years younger, I'm 66 now and just finishing my restore on my 70 1/2'er. it's taken me a year and a half, and loved every minute of the rebuild, congratulations to your work. OK caught the last few pics ,,nice job on the bed.
Larry
:Chevy: If you don't run your own life,, some one else will.
to our vets,, welcome home,, and thank you for your service.:Chevy:
seldomseen65 is offline   Reply With Quote
Old 06-05-2009, 11:13 PM   #164
67ChevyRedneck
67ChevyRedneck's Avatar
Use a check ball style vent for a motorcycle. That's exactly what I did on my truck. My truck has sat outside 24/7 since Nov. 2006 and I never got water in my tank.
I don't want to mess up your thread with pics of my truck, so check out post # 202 & 203.
http://67-72chevytrucks.com/vboard/s...+thread&page=9
Your truck came out beautiful, I love it!
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 06-06-2009, 12:26 AM   #165
matthew20061
69' Chevy Stepside
Larry
Thanks! I didn't even pay attention to it matching my hair till about a month ago which is funny. I'm going to take it to a car show tomorrow and see how many other 67-72's I see since there are quite a number of them up here just not restored or in good shape.
Thanks, I thought I would never see the end of this project but it's just about done. I'll see if I can find one of those motorcycle type check valves up here at a shop or order one.
-Matthew
Old 06-06-2009, 04:47 AM   #166
basketcase
basketcase's Avatar
Glad to help.
The bed looks fantastic. I'm guessing you won't be stacking concrete blocks in there anymore. What kind of wood did you use?
Tom
'69 swb stepside in progress.
'59 Corvette lifetime project
Old 06-06-2009, 10:00 AM   #167
67ChevyRedneck
If you can't find one local, they're on ebay too (this is where I got mine.)
http://cgi.ebay.com/ebaymotors/Gas-F...Q5fAccessories
Jesse James
Project "On a Dime"
Old 06-06-2009, 07:00 PM   #168
matthew20061
69' Chevy Stepside
Glad to help.
Tom
Ya not a work truck anymore....I'm actually not sure what kind of wood it is when I originally got the truck for free it came with it brand new.
I might just have to buy that!
-Matthew
Old 06-07-2009, 02:30 PM   #169
kev2809
low n' slo
kev2809's Avatar
amazing job man, nice color choice too. now you need to bag it! lol great truck..
kev2809 is offline   Reply With Quote
Old 06-07-2009, 02:47 PM   #170
kev2809
low n' slo
kev2809's Avatar
oh, what did you use to strip it down to metal?
Old 06-08-2009, 02:37 AM   #171
matthew20061
69' Chevy Stepside
Thanks, I was thinking of just lowering it since an air bad system would be $$$...
I just used a DA Sander, Wire Wheel on a grinder and a grinder on heavy rust or welds.
-Matthew
Old 06-09-2009, 03:02 PM   #172
matthew20061
69' Chevy Stepside
Well fixed my brake problem I did as basketcase said and plumbed new lines from the master cylinder to the proportioning valve. This completely fixed the problem now I have good front and rear brakes. Here's a pic:
-Matthew
Old 07-02-2009, 06:17 PM   #173
matthew20061
69' Chevy Stepside
I installed a Compustar Pro Security System In the truck last weekend. Now I can remote start it (yes pointless). The main reason I got it was because it has a very good security system. Door sensors, hood, shock sensor, and starter kill relay. Anyway seems to work good. It's pretty funny being able to remote start such a old truck. Still need to fix a power steering leak and install the rear view mirror on the windshield. I'll put up some pictures of the security system tomorrow.
-Matthew
Old 07-03-2009, 08:55 AM   #174
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Your truck looks really good man. It's been a lot of work but you stuck it out until the end and finished it and that's about as hard as the work Enjoy driving that thing!
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 07-03-2009, 09:34 AM   #175
Beautiful Truck!!
