Old 06-03-2009, 04:44 PM   #1
Hazieview
Building Dreams out of Dimes!
Hooking up! How do you guys get traction?
I am throwing some money in my sb400 and 350th but I need to make sure that after I can produce the power I can put it on the ground...
I'm looking for a .373 Posi and I am going to run 295 tires too. My truck has drop spindles and shackles/hangers.
So what could I do?
Ladder bars? Dont think so this is going to be a very streetable truck.
Traction bars? I heard the only time you can use these is if you have a flip kit. So should I install a flip kit?
I'm putting a fuel cell in the back and I may relocate my battery to the back.
Any suggestions on how I could Hook up any better?
Hazieview is offline   Reply With Quote
Old 06-03-2009, 04:51 PM   #2
Prerunner1982
Prerunner1982's Avatar
Re: Hooking up! How do you guys get traction?
You might look at what kind/type of tires you are running.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 06-03-2009, 05:40 PM   #3
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
CalTracs:
http://store.73-87chevytrucks.com/me..._Code=7387SUSP
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 06-03-2009, 05:52 PM   #4
babyJay
Arrived on a Pale Horse
babyJay's Avatar
tub it out and shorten the axle...
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 06-03-2009, 06:06 PM   #5
Wild83C10
Wild83C10's Avatar
Loosen up the front end. Buy some adjustable drag shocks for the front. Shift as much weight to the rear as possible.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 06-03-2009, 06:21 PM   #6
79gmcc15
Gettin It One Pice At A Time
79gmcc15's Avatar
Originally Posted by Captkaos View Post
how does this work? jw
RIP ELJAY
Work In Progress 1979 GMC C1500 Trailering Special.
Getting the truck done, one piece at a time.
“You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan
“I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby
79gmcc15 is offline   Reply With Quote
Old 06-03-2009, 06:28 PM   #7
Cherub
Cherub's Avatar
this is what im going
pics of the set up are in here
http://67-72chevytrucks.com/vboard/s...light=caltracs
Cherub is offline   Reply With Quote
Old 06-03-2009, 08:57 PM   #8
dammitmitchell
the pollock
dammitmitchell's Avatar
i get traction in second gear =-)
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 06-03-2009, 09:42 PM   #9
78 Chevyrado
I get traction through low power output....lol
78 Chevyrado is offline   Reply With Quote
Old 06-04-2009, 01:09 AM   #10
Hazieview
I too would like to know how the CalTracs would work on a truck without a flip kit....
Does anyone else have any pictures of there CalTracs on a nonflip kit setup? Or something like the CalTracs?
Old 06-04-2009, 01:10 AM   #11
pokethesmot
profeshinaly unimployed
pokethesmot's Avatar
put weight in the back
"having mud flaps is like asking for a smaller trophy"
pokethesmot is offline   Reply With Quote
Old 06-04-2009, 05:53 AM   #12
S10Fan
Old Heap Driver
LOL, I was going to offer up my 250-6, problem solved!
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 06-04-2009, 09:38 AM   #13
swb85
On a budget like Fred Sanford
swb85's Avatar
You do not need a flip kit to use traction bars (commonly referred to as slapper bars) or caltracs. They both do the same thing which is eliminate spring wrap (wheel hop). I have cheapy Lakewood traction bars on my truck (stock height) along with a locker in the rear end. If I had some better tires on there I'd probably hook pretty good, but with the BFG T/A's I can lay rubber for a city block.
If you REALLY wanna hook you need the following:
-posi rear
-TIRES (ie, drag radials)
-anti spring wrap mechanism (traction bars or caltracs)
-good adjustable shocks at all 4 corners
-move as much weight to the rear as possible
Keep your wallet handy because stuff starts breaking when you hook
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 06-04-2009, 09:41 AM   #14
thirdstreettito
Resident of Here
thirdstreettito's Avatar
The only way I have ever gotten traction is with a trailer or loaded bed.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 06-04-2009, 11:09 AM   #15
dieseldr4
hooking up 101...ha ha...
if you cant get enough weight to the rear, you can always fill the bottom half of the tailgate with lead, i have done 2 tailgate for local guys here in so cal. this works well and get the weight way back where you need it...lead shot or tire weights work good for this.. guess the cats outta the bag now... hope this helps...
dieseldr4 is offline   Reply With Quote
Old 06-04-2009, 11:31 AM   #16
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
That seems crazy, but I guess it works huh? You just drop them all through the access spaces? How much weight you use, any idea?
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 06-04-2009, 11:42 AM   #17
dieseldr4
it depends how much you need.. back in the mid-90's a guy named chuck samuels used to race n.m.c.a super street with a 65 elcamino(wicked truck that ran low 9's high 8's with wheels up launches! all that on 28x9 tires with stock suspension!), his wife used to put the tailgate up after a race, she was workin hard to lift it for sure.. i was in the staging lanes one day when they dropped it, dont know for sure how much he had in it but it sure sounded heavy.. ive done one with 75 pounds and one at a 100 pounds.. it just depends what your application needs, obviously you dont want any more than needed...you can also melt it down (wear the proper safety gear) and pour it down the tailgate handle hole... hope this helps you guys get these trucks hookin and bookin...
Old 06-04-2009, 12:21 PM   #18
Driveway Dreams
I have car A.D.D.
Thats great! Thanks for the ideas.
-Gerald
Old 06-05-2009, 12:24 AM   #19
team39763
I think you'd be very happy with the Caltracs...especially once you get everything working together - weight tranfer, motor/tune, tires, shocks. I only had half a run down the track with mine(lost a ujoint and twisted the driveshaft) and I seemed to hook pretty good. I gave them a try on the street and I could feel/see the difference.
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs.
Best time so far 11.8@XXXMPH
team39763 is offline   Reply With Quote
Old 06-05-2009, 06:04 PM   #20
Captkaos
Captkaos's Avatar
Caltracs work the same with either flipped or not. there are just 2 different brackets for the 2 versions.
Or where you wanting an explanation on how Caltracs themselves work?
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 06-05-2009, 09:57 PM   #21
AceX
>130dB Moderator
AceX's Avatar
Cal-tracs and a good set of tires should hold. If it doesn't there are less permanent ways to get wieght in the rear. There are "water bladders" which are bags that you fill with water. They can add up to 400lbs right above the rear end. It can then be drained for the drive home or w/e. Best solution I've found.
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 06-05-2009, 10:22 PM   #22
79gmcc15
79gmcc15's Avatar
for me that would be cool.
RIP ELJAY
Old 06-06-2009, 12:41 AM   #23
Hazieview
Yeah I'd like to know how the cal tracs work without using a flip kit...
