I've got grease on my mind.
Remote Starter Solenoid
I am adding a remote starter solenoid to my truck to help with a hot start problem in addition to a starter shield. I live in Washington State where it likes to get real wet, real often and the truck lives outside.
I am wondering where to mount it. Too high on the inner fender and there is a constant drizzle from the hood lip. Towards the front of the apron and you get water coming in through the radiator at speed, at the rear, moisture dripping from the rear of the cowl at the hood or a heater core leak. Mount it to the frame and it is exposed to splash up from the wheel and heat from the exhaust. I am thinking about mounting it in the little recess towards the bottom of the apron as indicated by the pic. Let me know what you think or pictures of what you have done. Thanks. |
Between Trucks...
Re: Remote Starter Solenoid
I don't have a pic, but I mounted mine on the inside of the fender above the inner fender, but it doesn't rain too often here.
Beat it to fit, Paint it to match... ![]() |
Are you saying in front of the hood hinge?
Between Trucks...
In front of the hood hinge, pretty much in the middle, above the inner fender.
its all about the +6 inches
they are designed to get wet... just like the starter.
Mount it away from the heat of the exhaust. if you mount it where you indicated, you'll be putting exhaust heat right on it... just like the one on the starter now. it'd be like taking a shower, and putting on dirty underwear. |
It is basically a Ford solenoid with a tab that goes from the bat post on the Delco starter to the solenoid post.
I'd mount it where it was out of the way and not close to heat from the manifold or where it could get splashed on. |
"taking a shower then putting on dirty underwear"! we might have an expert here!! Hummmmm
Look at any ford---they all use the remote solenoid and mount on the inside of the fenders about 1/3 of the way back. In this case, Ford had a better idea!! Andy is right on--. |
Ford USED to have the better idea. For some reason, they have ditched it.
However, with modern electronics, and gear reduction stuff, it isn't needed anymore. (late model OEM stuff) |
#9 | |
![]() Join Date: Feb 2000
I mounted mine on the passenger side fender - here you can see it a few inches from the battery.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 Last edited by Yukon Jack; 06-08-2009 at 03:42 PM. |
#12 | |
Will it run today?
Good luck!
Jaws, the 1971 Chevy Cheyenne Longbed. She's big, grey, and has an insatiable appetite! |
![]() Join Date: Apr 2005
2 questions:
1. Does anyone have a wiring diagram to do this mod? and 2. Will a high torque mini starter cure the problem? Thanks, R/ EDIT: Just saw the last post on the mini starter.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 06-08-2009 at 05:09 PM. |
Mount it to the bottom of the battery tray with scew and nut.
#15 |
a high torque starter is the better fix.
