JY sway bar question -
I got this sway bar off a 1-ton at the JY - it's a 1-1/4" bar, but my question is, it has a lot of scaling/rust on it, and I wanted to clean it up before I installed it. If I clean off the scaling, will it make the urethane bushings fit too loosely? Has anyone ever done this before?
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 |
Dave's not here, man
Re: JY sway bar question -
Mine was in similar condition when I got it and I hit it with the wire wheel attachment on my grinder. I didn't cause any installation problems. I think you should be fine.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
#3 | |
its all about the +6 inches
![]() ![]() ![]() I've seen those things rust in 1/2! you can sand blast it, sand it with a sander, hit it with a wire wheel or a grinder.... there's not enough there to matter. |
Cool, thanks guys, I just didn't want those bushings to be sliding around too much.
