Old 06-09-2009, 10:21 PM   #1
dolphman88
DDOV
dolphman88's Avatar
Re: operation daily driver... my new 64
ordered front cab supports, and partial rockers today.. almost finished sandblasting cab but weather stopped me a little shy..
pulled motor and trans out of old truck and prepping for re-paint and hopefully placing on frame soon.
QUESTION.. has anyone ever used aircraft paint remover?? thinking about using that from now on instead of sandblasting..
If you don't like the way I drive, stay off the sidewalk
http://67-72chevytrucks.com/vboard/s...d.php?t=317070
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
dolphman88 is offline   Reply With Quote
Old 06-10-2009, 12:11 AM   #2
neto
neto's Avatar
I used the air craft paint remover but didn't really work that well. Sand blasting will but what a mess. I did grinding, wire brush, paint strip pads, paint remover and sand blasting on my cab.
neto is offline   Reply With Quote
Old 06-10-2009, 12:37 AM   #3
Captainfab
60-66 Nut
IMO media blasting (sandblasting) is the only way to go, but you need the proper equipment so it isn't a big PITA. Paint stripper has it's place such as large flat panels than would likely warp if you were to blast all the paint off. You can take most of the paint off with the stripper and then dust over it with the blaster.
Old 06-10-2009, 04:39 PM   #4
dolphman88
DDOV
dolphman88's Avatar
i was advised at work today just to blast the around all the edges, and hit the rest with the DA i guess ill do that
Old 06-10-2009, 07:42 PM   #5
protrash64
Resistance is Futile
protrash64's Avatar
There is a bunch of info in paint and body section on this subject. Seems people go back and forth on what they like. If you're sick of dust, stripper is the way to go.....but then you have a mess of goo to clean up. It appears that neither method is exactly perfect.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
