Old 06-09-2009, 06:15 AM   #1
dave6672
dave6672's Avatar
1972 K20 Upper Ball Joint Removal Help
I have a 1972 K20 and am replacing the ball joints. I have removed the knuckle and have removed the lower ball joint. I'm trying to figure out how to remove the upper ball joint. According to the shop manual there is an adjusting sleeve that is screwed into the knuckle and the ball joint is inside the sleeve. It appears to be pretty well rusted together. How should this be removed? Does the ball joint need to be removed first, then the sleeve? Or do you screw out the sleeve along with the ball joint? Any suggestions on the best way to remove this would be appreciated.
dave6672 is offline   Reply With Quote
Old 06-09-2009, 07:16 AM   #2
Rust Buster
Rust Buster's Avatar
Re: 1972 K20 Upper Ball Joint Removal Help
Not a fun project!! The ball joint has to be removed before the sleeve. I just used a vise and a hammer to get out the old ones, but then bought a ball joint remover (about $50) to put thee new ones in so I wouldn't marr them. The tool is a good investment. Other than that, just lots of patience and hammering. You can also try heat to expand the knuckle. Also, make sure you are pushing it out the right end, it is a little confusing. I believe the top one comes out underneath the top knuckle, not out the top. Hope this helps.
Maj USAF
71 K5 Blazer CST
72 K20 HT383 NV4500 Mass-Flo EFI
71 K10 LWB
52 Dodge Power Wagon
67 Dodge WM300 Power Wagon
48 Dodge WDX Power Wagon
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=239487
Rust Buster is offline   Reply With Quote
Old 06-09-2009, 08:52 AM   #3
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
if its original theres rivits under those bolts, you gotta grind the top of the bolt head off and knock em thru with a chisel..not bad...may wanna wear long sleeves and googles/gloves a nasty job for sure.
John
1999 Toyota Tacoma 4x4
Old 06-09-2009, 10:15 AM   #4
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Keep in mind that this is a Dana 44 front axle, 4x4. I believe you are describing a 2WD front end??
D.PASSMORE is offline   Reply With Quote
Old 06-09-2009, 09:56 PM   #5
oldblue1968chevy
yee you right im wrong read the post wrong ignore my last post im a lil senile someimtes lol
John
Old 06-11-2009, 06:16 AM   #6
dave6672
dave6672's Avatar
Thanks for the advice. Hopefully this weekend I'll get a chance to work on it.
