06-08-2009, 09:42 PM | #1 |
Wrong Kickdown Cable Help?
I recently ordered a universal throttle cable and an 700r4 kickdown cable from Lokar to replace my current setup. I thought I had an 700R4 trans...
I think I ordered the wrong kickdown cable ... the TV cable tube that slips into transmission is smaller than the Lokar 700R4 kickdown I purchased. Do I have a different transmission than I thought?(700R4) Do I have an 4L60? Are KD cables different from the 700r4 to 4L60? Thanks for any help...
71 Chevy C-20 Fleetside Stock 402 BB-Summit Headers-700R4 Trans Dual 40 series flowmaster w/ H pipe Edelbrock 2161 intake & 1411 Carb |
06-08-2009, 11:02 PM | #2 |
The Older Generation
Re: Wrong Kickdown Cable Help?
Any chance the trans could be a 200r4? I don't really know the differences in them, if there are any. Anyways, this will get your post back to the top.. LockDoc
06-08-2009, 11:14 PM | #3 |
its all about the +6 inches
did you tell them it was an overdrive? If you just said kickdown cable, it's probably for a 3 speed. they were called TV cables on the 4 speeds.
06-08-2009, 11:21 PM | #4 |
Upon further inspection I still think it may be an 700R4.
The serial number in passenger side corner is 4YK147BT anh housing hax MD8 on bell housing...from serial number its a 1984 model any clues what is the right kick down cable? Yeah it's an overdrive... Do I need an Lokar TV cable for an 700r4?
71 Chevy C-20 Fleetside Stock 402 BB-Summit Headers-700R4 Trans Dual 40 series flowmaster w/ H pipe Edelbrock 2161 intake & 1411 Carb Last edited by mleeb; 06-08-2009 at 11:23 PM. |
06-08-2009, 11:31 PM | #5 |
The part number I bought is :
KDP-2700HT Polished Hi-Tech 700-R4 Kickdown Kit
06-08-2009, 11:33 PM | #6 |
you considered a GM part?
06-09-2009, 02:10 AM | #7 |
Yeah... I'm thinking I may just modify existing gm tv cable to fit I lokar bracket ...
Thanks for your help!!
06-10-2009, 04:40 PM | #8 |
[IMG][/IMG]
Here is a pic of the existing GM part and the 700r4 Lokar part I bought... I just cut GM part to fir Lokar braket but still curious what type trans TV do I have...
06-11-2009, 06:49 AM | #9 |
Does it have a vacuum modulator? 700r4 has no modulator, 200r4 should have an extra set of bolt flanges at the top for BOP applications. Take a picture of the trans pan, then someone here can tell you what you have.
