Factor Sound Deadning
So I discovered today looking at my floor that it appears the floor has like little metal bumps or something underneath the stock sound deadening material and unfortunately one of these has worn a hole clean through the floor.
So my question is have many of you removed this material? And if so what was the fastest and easiest way of doing it? I heard that dry ice can work but I don't think it'll work with this material and I found today that using heat and a flammable liquid will melt it into a pile of goo to scrape off. Last edited by enaberif; 06-08-2009 at 01:45 PM. |
Arrived on a Pale Horse
Re: Factor Sound Deadning
You shouldn't remove it unless you absolutely have to. If the engine erupts in flames driving down the road it will help insulate you from the heat long enough to pull over and get out of the truck (hopefully). If you do remove it put something back in it's place after you've patched the floorboards, something like Fat-Mat.
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
#3 | |
Just trying to find the easiest and less messy way.. but I don't think that will happen ![]() |
I don't remember either trucks I disassembled it being a problem. I don't remember it being glued or stuck down. I just yanked it outta there.
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
I just pull all of it out of my Blazer (not the firewall yet) pretty much came straight out as all the others did.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
profeshinaly unimployed
get a good firm grip and rim it out
"having mud flaps is like asking for a smaller trophy" |
#7 | |
I've tried. Its stuck to the dang floor and GOOD. |
well i did encounter a few areas that were a little tough and just spray some brake cleaner on it
That brake cleaner has so many uses. Did you know it will also kill wasps? The brake cleaner should help soften or dissolve any glue or stickyness. It evaporates pretty quickly, so get yourself a couple cans of it. Also if you have an old can of tar remover in the shed, dump it on there and let it soak.
#10 | |
I thought mine was attached to the floor at one point but it was just the rust bonding it to it's self.
Evan B. |
Yo! All my crappy flooring came up easily, with a layer of rust attached to the bottom of it! With no back window, and on it's belly in a cow pasture for four years, it didn't suprise me.
Todd.
'78 3/4 ton 4x4 custom "Todd-built" FRANKENTRUCK! |
