Old 06-10-2009, 08:02 PM   #1
69C10@16
C-Notch. What is the max drop without it?
Okay guys, I've heard a LOT of different opinions on how far you can drop a truck in the rear without C-Notching the frame. I want to go a 3.5-4/6 Drop but I don't want to touch the frame. I'm okay with having to get the shock relocators and the adjustable panhard bar. So, can I do it? Or can I just go 5??
69C10@16 is offline   Reply With Quote
Old 06-10-2009, 09:26 PM   #2
see ten
WTB this ad
see ten's Avatar
Re: C-Notch. What is the max drop without it?
How do you intend to use the truck?
In my experience light to no hauling is fine with a 6" drop and no notch...If you don't mind it bottoming out occasionaly.
If you never want it to bottom out for light hauling 5" should put you where you want to be.
Heavier hauling?...Probably want to put some bags in there to compensate for the load and keep the axle away from the frame.
see ten is offline   Reply With Quote
Old 06-11-2009, 12:55 PM   #3
68_chop_top
68_chop_top's Avatar
I went with 6" drop in the rear (4" drop spring and 2" blocks) and have never hauled anything and never seemed to need the c notch.
I had to cut the 2" block in half to go back to a 5" drop to make the truck sit level (not tail dragging look) with the 2 1/2" drop spindles and 2" drop springs in the front.
Mine is chopped, has a clutch, and a big block.
68_chop_top is offline   Reply With Quote
Old 06-11-2009, 01:17 PM   #4
scott's69
WORTHLESS CRUISERS
scott's69's Avatar
Ive got a six inch drop with no notch. I haul lots of stuff to shows and cruise ins but I never bottom out. Of course you need good shocks and springs.
Scott Hammond
Lancaster, SC
1969 Chevy2005 Chevy Silverado Z71 72 Chevy 1972 SWB 454
If you don't live for something, then you'll die for nothing. www.xclusive-images.com
scott's69 is offline   Reply With Quote
Old 06-11-2009, 02:17 PM   #5
72BlckButy
Tot Roddin'
72BlckButy's Avatar
As previously posted... about a 6" static drop in the rear without a C-notch is all the farther I would go.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 06-11-2009, 04:08 PM   #6
brad_man_72
the boat guy
brad_man_72's Avatar
i have 5" lowering springs in the back of my truck, 1/4" from the bumpstop empty, on the bumpstop if i get in bed. doesnt ride bad empty.
i thionk im going to need a slightly different setup because i just got a under bed fuel cell and my stance is off.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 06-11-2009, 04:11 PM   #7
lyrikz
PITbut
lyrikz's Avatar
Here is how low you can go... Actually not even that low, cause on hard bumps the frame hit the axle.
New project. 1971 Twin Turbo blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=676047
My new YOUTUBE channel.. Videos of my truck and a current walk around.
Lyrikz74 Youtube channel DONE! SOLD!
My 1971 stepside build thread
My Build Thread UPDATED 6/11. DONE
and sold.
lyrikz is offline   Reply With Quote
Old 06-12-2009, 08:10 PM   #8
69C10@16
Do not intend on hauling anything really. Maybe the occasional lawn chair to the drive in movies or something but that would be it. Ive got a 99 GMC Sierra to do the heavy stuff. Thanks for the help guys. Sounds like I'm going to be able to go 6" without any trouble. Much obliged boys much obliged.
Old 06-12-2009, 08:12 PM   #9
lyrikz
PITbut
lyrikz's Avatar
Thats the thing.. YOUR GOING TO HIT.... My truck has a 5"-6" drop in the rear... UNLOADED and on the freeway if you hit a bump it will DONK on the axle... Thats a 5 inch drop. UNLOADED... Your gonna go 6"s i guaruntee you its going to hit... Just fyi.
and sold.
Old 06-12-2009, 08:48 PM   #10
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I've got literally over 100k miles on my truck with 6 inch rear drop springs and no notch. It's fine. I have hauled Honda Goldwings in the bed (really, I'm not kidding) and it will bottom out then.
The secret is to remove those crazy tall stock bump stops. If you leave them in place, you are certainly going to hit all the time. Get some little short bump stops and you are golden.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 06-12-2009, 11:48 PM   #11
lyrikz
PITbut
lyrikz's Avatar
Mine didnt have the bump stops. ahaha.. I guess all the trucks are different.. Mine hits all the time, unloaded, no bump stops.. Yours never hits... EIther way, if it hits, just put the notch in
and sold.
Old 06-13-2009, 07:18 AM   #12
Tx Firefighter
What brand rear springs do you have ? Mine are Early Classic. I once had a set of Eibach rear springs. They were much softer than any I had ever seen.
Old 06-13-2009, 10:27 AM   #13
lyrikz
PITbut
lyrikz's Avatar
Early classic fronts and rears. Now its all bagged and notched. ahah
and sold.
