06-11-2009, 06:59 PM | #1 |
Fender Trimming tips....
Oh boy here we go....
I started this project knowing I was going to do this to my rig but now I have the hives thinking I'm gonna screwup chopping a mint 72 GMC Jimmy. I've customized a number of real nice vehicles with not even a second thought but for what ewver reason I'm a little nervous going into this. Looking for tips to trim the front and rear fenders. I've got the required tools for cutting: plasma and die grinder but I think I lack the tools to properly finish the edges. I'd like to roll the edges over to make a 1/2" lip thinking that this would provide a ridged and finished fender again but I'm not sure how to do that with you average set of old guy workshop tools. I've actually thought of welding in a formed piece of flatstock as well. Any suggestions? I know it is for wheeling and this may seem over the top but nobody says I can't have a well done wheeling rig right? Also if the above turns out to be a bust does anyone have some recommendations on fender flairs? No looking for anything gaudy just simple and fuctional in that it hides the chop job.
72 GMC Jimmy, 350, sm465 np205 (getting a face lift) 64 Nova SS, 327 SC & gassed, TH350. (blowed it up) 84 HD FX frame,80 FL tins, evo with 85hp/90tq (wifes bike) 96 HD FatBoy evo with 102hp/100tq (mine!) KEEP NOTHING STOCK! |
06-12-2009, 02:15 AM | #2 |
the pollock
Re: Fender Trimming tips....
burt4x4 did his...
he would be the best (in my opinion) to take advice from... he did a damn good job.. (just a little jealous)
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
06-12-2009, 09:00 PM | #3 |
I just ordered some JC Whitney Surface mount Flex Flares. I also got some advise to just cut the fender and spot weld in some flatstock to add some ridgidty back. The one last thig I have to work out is the inner fender cutting and forming for the front.
06-13-2009, 10:46 AM | #4 |
I just cut the front fangs off and 'tips' of my wheel wells were the tires touched. I did not roll the cut sheet metal. Then I cut out my rockers and pushed a 2"x3" square tubing in it's place for rock sliders.
VT & Greg72 ARE the body masters!!
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks |
06-14-2009, 07:55 PM | #5 |
I'd really like a few pictures of those Rocker/Rockslides!
06-15-2009, 02:50 PM | #6 |
Sorry no pics of the underside, I basically welded it to the rocker box.
06-15-2009, 03:03 PM | #7 |
Geez from your avatr it looks like you passed up a perfect opportunity to get a few shots of the underside!
Thanks the Pics are helpful, I was wondering if I should just weld sliders to the boxes, now I have my answer. I cut the back of my rear fender yesterday, Used an electric shear to nibble about 3 inches from the bottom most rear and tried to blend it into the fender line about 8 inches up. I then used some heat on the inner fender and banged it flush with my outer. I plan to spot weld in a little material where there is a gap between them. I'll post up a few pics when I get it done.
