Shlongbed #20
![]() Join Date: Apr 2009
Truck dies at every stop sign
Hello all! Well i drove the truck to work today to get it registered and at every stop sign it dies on me. HAs anyone run into this? Im sure someone on here has. I was thinking that the carb needs rebuilt. The PO said that the float was hosed and it is seeping a little but not a major deal.
SEMPER FIDELIS - USMC 1962 Chevy C10 LWB StepSide 235/4 speed ![]() 1976 GMC Sierra C15 LWB Fleetside 350/350 ![]() ------------------------------------------- 1999 Acura Integra LS ![]() 2008 Vulcan 900 Custom |
Sunburst C10!!!
Re: Truck dies at every stop sign
its not dying its fainting every time it sees red
![]() i would say it was the carb you could do a tune up and a carb rebuild and it would probably fix the problem i bet when it not under a load it floods and soaks your plugs how long does it take you to start it after it dies what engine is this if the float is leaking at all it needs to be changed that will cause it to flood
Gage 1967 C10 Shortbed Stepside Last edited by jgh64pkup; 06-15-2009 at 12:32 PM. |
Shlongbed #20
Thats too funny!
![]() Steve
1962 C-10
My first oldie was a '51 Chevy 3100. I cruised it with a 235 for a good while...with the choke about a 1/4" pulled out! I'm not sure why, but it ran better that way. I never changed a thing...until we put a 350 in it later.
Joseph Chavez ![]() "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
Could it be a vacuum leak somewhere? If you are having to pull the choke then it's running lean. If your float has a leak then it won't empty that fast for you to restart and drive away.
Shlongbed #20
For some reason it just runs better when the choke cable is out 1/4 of the way like jchav62 said. Could be that the cable is misadjusted? The carb needs rebuilt anyhow since the bowl is seeping. I dont think that there even is vaccum lines on this engine to be honest but could be wrong. I havent had it that long to pay attention to that... If i figure it out i will post to let everyone know what it was... Thanks for your help guys!
#7 | |
Just here to tinker
![]() Join Date: Jun 2008
![]() Also it wouldn't hurt to check that the base bolts are tight, but since you rebuilding it anyways, you'll find that out.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
Sunburst C10!!!
Gage 1967 C10 Shortbed Stepside |
Learn to drive stick
