06-15-2009, 08:19 PM | #1 |
Formerly- 1972SuperCheyenne
Cab corner question
Are the cab corners on our trucks originally double layered? I have some rust on my cab corners but it appears to be only on the outer layer. I suppose I can just replace the outer layer??? Never knew they were like that.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
06-15-2009, 08:30 PM | #2 |
Re: Cab corner question
No there should be only one layer. Although in some parts of the corner there are floor supports that the corner might be tack welded to. Where exactly is the rust at. Maybe try and get a picture.
07 Chevy classic LBZ Duramax (a few mods) '67 Chevy 1/2 ton 2wd (in pieces) '69 Chevy 1/2 ton 2wd (on hold) '71 GMC 3/4 ton 4x4 ‘71 GMC 1/2 ton 2wd suburban |
06-15-2009, 10:01 PM | #3 |
I tried to get some good pictures but the light was terrible and the pics didnt turn out.
06-15-2009, 10:22 PM | #4 |
There are places where the cab corner overlaps metal, like at the b pillar and up against the rear of the floor section. But other than that its probably had new corners placed over the old ones. Bad move for sure, but more common years back or by someone not in the no, or just someone hacking it for a quick resell.
"I'll Procrastinate Tomorrow" quote by LEEVON 71 K10 long fleet (sons truck) new 370hp 355, sm465 np205, 3.73's 33's 70 K20 long fleet 98 G3500 work van |
06-15-2009, 10:58 PM | #5 |
Here is a pic from when I did my corner's, you can see some of the metal that is under the corner. Is that were the rust is?
06-16-2009, 08:05 AM | #6 |
No this is in the very bottom corner. This cab has never had any panel repair in the past. It was a Texas truck and is super solid.
06-16-2009, 08:21 AM | #7 |
Here is the only pics I have. You can look inside the cab and see there has never been any replacement of the cab corners. But you can see there is definately two layers of metal.
06-16-2009, 08:53 AM | #8 |
It`s a single layer from factory.Not sure what you have going on there.But,I`d still get "all" that rust out of there.You`re repair won`t last if you don`t.In fact,it will go bad real quick.moisture will build between layers and the inner layer is aweful rusty already.I think it was repaired by laying over the outside and what you see is the result of what i`m talking about.
06-16-2009, 09:00 AM | #9 |
I have great blobs of sealer material gooped into the corners on the inside of mine. If you poke through the holes, it looks a lot like what you see there, the rust stuck to the goop.
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
06-16-2009, 09:15 AM | #10 |
No telling. Either way it'll all be cut out very soon. Cant wait to get this cab on the chassis so it can start to look like a truck again.
