![]() Join Date: Mar 2004
Bags rub when deflated
Is it common for convuleted bags to rub the spring pocket when fully deflated? Should I expect premature bag wear because of the "soft rub"?
The application is a daily driven 2005 Suburban that will be deflated/inflated 2x a day. Front View ![]() ![]() Rear View ![]() |
Re: Bags rub when deflated
Everytime it inflates/deflates, it's rubbing. Anytime it rubs, theres wear. Anytime there's wear, there's a possibility for failure (sooner or later).
I would clearance the offending material ASAP.
#3 | |
My concern with removing the offending material is structural integrity. A LOT of material would need removed from the side of the spring pocket for clearance. I guess the question is how much material can safely be removed (I don't expect anyone to have the answer ![]() Looks like I have 3 options:
Signed - Frustrated |
Option #3 sounds like it's the safest, best planned approach. Try contacting Tony from ART & see what they might suggest.
Señor Member
![]() And then replace the bags. The spots that have already rubbed are not going to repair themselves... they'll be a weak spot of unknown integrity for the rest of their lives. Don't find out how weak they were while tooling down the highway.
He said it's fine because the bag is hitting a smooth surface while deflated.
I'm still in the process of converting to air ride so the vehicle has yet to leave the shop. Good suggestion though...
#8 | |
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 06-16-2009 at 03:57 PM. |
heat the pocket ears up and beat them over with a hammer. you only need a little room so dont get too crazy.
where it rubs the lower mount its fine. and remember, every oil change at the LEAST get under there and check the bags. |
#10 | |
I'm running the CoolRide setup. Not sure about the diameter or if a smaller size can be run and still support the weight of the vehicle. |
#11 | ||
![]() I like cajun's suggestion of heating & bending the 'pocket' lip for the necessary clearance. Seems that would be less invasive vs. cutting it completely out & welding in a new upper. It's worth a shot anyway.....
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 06-16-2009 at 06:30 PM. |
Keepin it old school
I would def not leave it as is thats for sure!
#13 | |
Thanks for all the suggestions guys. Last edited by LooseCannon; 06-17-2009 at 08:07 AM. |
what if you went with a smaller dia bag with the same weight cap.?
#15 |
A guy with a truck
Mine did the same thing when I first installed it. There is some wiggle room in where the bags are located using the upper mounts. I moved them as far away from the clearance issue area as possible and solved 99% of it. I would still like to use a 2500 vs the 2600 bag to gain that last little bit, but I'm not sure the way the ART cuups are designed will allow this...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#16 | |
