44s on a 79 Blazer
Im looking to buy some 44inch tires for my blazer. Has anyoner done this that can help me out with infomation? The blazer is a 79 with a 400 engine 350 tranmision and i think a np203 transfer case twelve bolt rear and ten bolt corp front. Ill use it for camping and some wheeling like rivers mud and hills? What lift kit do i need? Can i run the same axles or can i do th 14 bolt rear what about the front? Thank you for any info you can help me out with Los
68 GMC-Stripshow 70 Chevy Monte Carlo 72 Chevy Monte Carlo LOLO 72 Chevy Suburban Blurban 74 Vw Bug 78 Chevy k10 lwb 78 Chevy k10 swb 03 Cadillac Escalade-Duecesix 84 Cadillac Coupe Deville DeElegance ![]() ![]() B.O. A Lifestyle Money Cant Buy! Win,Lose, or Tie I'm a Raider till i die |
Arrived on a Pale Horse
Re: 44s on a 79 Blazer
This is 38's on a four inch lift, and it was too much, and the fronts rubbed. Went back to 33's and saving for Bushwacker flares and TSL 37's. I would say you will need at least an 8 if not 12 inch lift.
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW Last edited by babyJay; 06-11-2009 at 01:17 PM. |
That is a good lookin truck i was think that to 8 or 12 inch lift is what im gonna need 8 with trimming
#4 | |
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
i know it funny how we get the deals on trucks then end up putting parts that cost more than the truck i
#6 | |
alot of what i pick up should go there but you cant let history go that easy lol
Just to give you something else to think about. I have a 1987 3/4 ton Suburban with an 8" Superlift kit on it and 36x15.50's on a 12" wide rim and they will scrub on the front corner of the front fenders when I am turning really sharp. I know that my Sub weighs a good bit more than your Blazer though. I do know that the narrower the wheel and tire you go with the less lift and trimming you will need to do. I would try a set of 42" TSL's on a 10" wide rim. The 42's are a little bit narrower and I think that they look great!
WHEN DOING a lift i always like lifting the body also.For cleaning purposes a quick small lift don't need nothing but your mounts and adjust everything else
thinair
![]() Join Date: Jun 2004
12 suspension and 3 body to clear your 44's.And if you are wheelin it they will still rub......IF you are going to wheel it.......throw your half ton stuff away.If you get it to move,that stuff will break.Go with atleast the 3/4 ton 14 bolt-FULL float-and a 44 or 10 bolt in the front with atleast 4.10s.........I ran 5.13s with my 42s............
well thank you all for your information think im gonna rethink this since i still wanna do camping trips maybe 40s or 39s i got get that thing going projects!
