Old 03-25-2003, 03:17 PM   #1
GMC JUNKIE TOO
THE QUICKER FIXERUPER
GMC JUNKIE TOO's Avatar
control arm bushings
Saturday I am going to install my disc brake kit on my 69 and i went to buy contril arm bushings and the guy at napa said I had to buy the shafts and all because the bushings were steel they wanted 51.00 a pice for the uppers ans 61.00 for the lowers is this my only option?
Thanks Ben
GMC JUNKIE TOO is offline   Reply With Quote
Old 03-25-2003, 05:56 PM   #2
crazy longhorn
Fabricate till you "puke"
At one time you could get the bushings at the dealer, & they work if you dont have too much slop.......thats not usually the case tho! the shafts wear too, & as a rule, you are better off to replace the shafts also. There is no point in doing the job twice Good luck,crazyL
crazy longhorn is offline   Reply With Quote
Old 03-25-2003, 09:24 PM   #3
slogo
slogo's Avatar
give early classic enterprises a call @ 559.291.1611 or 559.291.1773
slogo is offline   Reply With Quote
Old 03-26-2003, 12:15 AM   #4
GMC JUNKIE TOO
Lmc has the shafts for 30.00 upper or lower. I am going to buy a set.
Old 03-26-2003, 04:34 AM   #5
sgtjed
What if?
sgtjed's Avatar
this is why when i do my discs on my 70 i am changing the upper and lower a-arms to the 73 and up style that uses the rubber bushings. they cost me 4.99 a pc for the uppers and 6.99 a pc for the lowers,compared to 30 bucks for just one upper shaft and bushings, for the steel ones.
2002 red extended cab Silverado
2002 Wheatland yellow Suburban
sgtjed is offline   Reply With Quote
Old 03-27-2003, 10:21 PM   #6
hugh e banks
bushings & other parts
hey i just found the most *****in place on line that will source out more than one manufacture at the same time .
www.1carparts.net give it a try .
and by the way the singe bushings are trw part number
k6147 and the upper is k6098 they are sold individually.
the lower shaft number is 13168a and the upper is 13167a.
if everything seems under control your just not going fast enough.
11 second pickup
hugh e banks is offline   Reply With Quote
