profeshinaly unimployed
i think my front end is gettin saggy
my front leaf springs are starten to bend backwards slightly does this mean im gunna need new springs soon there past the point of being flat they have a downward arch to them
"having mud flaps is like asking for a smaller trophy" |
Resident of Here
Re: i think my front end is gettin saggy
They are supposed to be "inverted".
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
Robert Olson Transport
![]() Join Date: Oct 2002
if they are sagging you can have them re arced and add a leaf cheap
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
Resident of Here
Also, here is a great 4x4 site, lots of great parts.
http://www.offroaddesign.com/ Like this! http://www.offroaddesign.com/catalog/Zero%20Rates.htm
how many more leafs can u normly stack with the stock u-bolts cuz my u-bolts seem to be maxed out...so what other kind of truck and i take the u-bolts from to use on mine
6.0 powered square
I wouldn't use used u bolts, you should be able to get all 4 for less than 30 dollars at any parts store, but if you had money to spend I would get some new leaf springs since yours has over load spring that shouldn't be there or just leave it like is and fix the really bad things that are bad first
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
what do overload springs look like...sorry for the dumb question
Resident of Here
If I were you I would make a list for the K10.
In order of most important. Make the truck run correctly (tune up, check gaskets, etc) Stop it from leaking so much oil Stop worrying about things that dont matter much(leaf springs, new tailights, etc) Get a piece of paper and write all of it down, if you dont know what the problem is, ask. If the truck doesnt sound like a normal (305 or 350?), ask about it. From what I can see from one of your pics of your truck in the garage you leak a lot of oil, find out where it comes from, oil drain plug? Oil pan gasket? And one thing that comes in handy is Google web searches and Google image searches so I know what I'm looking at.
#9 | |
Resident of Here
How about differentials? Pinion seals good? Cover gaskets good?
