Old 06-21-2009, 01:49 AM   #1
myfirstcarwasa73trk
myfirstcarwasa73trk's Avatar
Number from my 350 ?
what could br told by this number?
myfirstcarwasa73trk is offline   Reply With Quote
Old 06-21-2009, 02:06 AM   #2
'72customdeluxe
Re: Number from my 350 ?
That block can be 2 or 4 bolt mains, you just have to pull the oil pan to see. It's a common 4 inch bore block. So it could be a 302, 350, or 327. If there is 010020 by your oil filter, it's a high nickel and tin block
'72 cheyenne super step, '05 long bed gmc
'72customdeluxe is offline   Reply With Quote
Old 06-21-2009, 02:08 AM   #3
GruntMoanCough
GruntMoanCough's Avatar
Last digits (010) designates it as a 4 bolt main block.
My goal in life is to be as good a person as my dog already thinks I am - Unknown
GruntMoanCough is offline   Reply With Quote
Old 06-21-2009, 02:13 AM   #4
'72customdeluxe
from mortec.com
3970010....302.....69....4...Z-28 Camaro
3970010....327.....69....2...Trucks and industrial
3970010....350...69-80...2 or 4
^ that's 2 or 4 bolt mains, but in trucks, yeah, they are mostly 4 bolts. But that might not be the original motor
Old 06-21-2009, 02:28 AM   #5
GruntMoanCough
Well HEdouble hockey sticks! I always thought that 010 blocks were either LT-1 or truck 4 bolts. I've never seen a 2 bolt 010.
Thanks for the info.
Old 06-21-2009, 09:23 AM   #6
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
it's hard to tell from the down view....but are those camel hump heads? As easy as it is.....I'd pull the valve cover and get the casting number of the heads. Although anything is possible, sometimes the heads can help narrow down what the block MIGHT be. Long shot but it would be fun if it was a long block. Not too sure about the truck motors being mostly 4 bolts though.
prostreetC-10 is offline   Reply With Quote
Old 06-21-2009, 09:47 AM   #7
bac1755
bac1755's Avatar
I have the same block casting in my shop. Mine is a Large journal 327 4 bolt main.
1971 GMC
1972 Small Blocked DATSUN 240Z Dads old car
bac1755 is offline   Reply With Quote
Old 06-21-2009, 09:56 AM   #8
Shyguy
Junior Member
Shyguy's Avatar
Do you have the numbers and letters that are just below the front passenger head on the small flat spot on the front of the engine?
That is what I normally use to determine what engine is in vehicles.
Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 06-21-2009, 10:05 AM   #9
LONGHAIR
The odds of it being a 302 from a '69 Z/28 are about a million to 1.
If the heads are original (who knows) the accessory holes pretty much knock out the 327.
Greatest percentage 350.
It is been said for a lot of years that a 350 engine with a "factory equipped" 4 barrel carburetor would be a 4-bolt main. But I wouldn't count on it, GM did a lot of kooky things back in the day.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 06-21-2009, 11:05 AM   #10
myfirstcarwasa73trk
here are the other set of numbers
Thank you guys for the help
Old 06-21-2009, 12:25 PM   #11
WorkinLonghorn
WorkinLonghorn's Avatar
Both of my '69 350ci trucks had that 3970010 block,both were 4 bolt mains. This last one worked great until a rod decided to run away from home.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 06-21-2009, 02:16 PM   #12
mrein3
mrein3's Avatar
I personally own two 350s with that same casting number. One is a 2-bolt main, the other a 4. The two bolt one is now the 383 in my truck.
Don't get too hung up on the 4-bolt main cap thing. In stock form it doesn't matter much.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 06-22-2009, 12:34 AM   #13
myfirstcarwasa73trk
Was that the right set to tell for sure what it is I just want to be sure when I tell people its a 350 that I am correct.
Old 06-22-2009, 12:54 AM   #14
prostreetC-10
My Carbon Footprint
mrein3 gives good advice on the 4 bolt. We get too hung up on 4 bolts. Blower....NOS....that's one thing. I realize that wasn't really what you were asking too. Lots of BBC's were 2 bolts and usually good up to 600hp! The dynos don't lie.
You can always pull the heads and measure the piston bore! lol
Old 06-22-2009, 12:57 AM   #15
prostreetC-10
My Carbon Footprint
PS....as stated above; if the block hasn't been decked and removed the numbers off the pad on the pass side of the block, just under the front of the head, that's the best way to tell really what it is. There will be a 2 or 3 digit suffix (letter, not numbers) that you can trace. This is, of course, assuming it hasn't made a trip to the machine shop.
Old 06-22-2009, 07:14 PM   #16
myfirstcarwasa73trk
ok got the nubers there too then how much of that is needed? camera will not take pics but got 151188154 k04 17 cmj so what dose this tell me?
Old 06-22-2009, 07:53 PM   #17
prostreetC-10
My Carbon Footprint
I only checked ONE source but taking the casting number and the suffix code (cmj), it should be a 1974 police 350 with a 4 barrel. I can check other sources later but this is probably accurate.
P.S. This means that you should be able to outrun most of the police in your town!
P.S.S. Didn't say 2 or 4 bolt.
Old 06-22-2009, 10:59 PM   #18
myfirstcarwasa73trk
ok i see what you mean so thats neat anything more?
CMJ 1974 350 t4OO police - 4 full size
Old 06-22-2009, 11:12 PM   #19
prostreetC-10
My Carbon Footprint
correct...the other numbers are part of the VIN.
Old 06-22-2009, 11:42 PM   #20
myfirstcarwasa73trk
Well so far what I know is I have a 1976 high nickel and tin block made in Canada it is 4 bolt main it was stamped on April 17, 75 or 76 and could have a problematic valve train, but mine has been replaced. Any way and most important to me is that it is a Chevy!!
I could really care less if it was 4 or 2 I am not racing just my daily driver was in my 1985 for the last 6 year! Now at home deep in my
1967 C-10
Not sure why everyone got caught up on that I wanted to know just a little history, so when I am at the gas station or a car show and some one ask I don’t stand there catching flies with that dumb look on my face!!! lol
Man you guys are very helpful Thank You!
Now my next question where do I find the extension for brake peddle Rod and how long is the right length?
Old 06-22-2009, 11:50 PM   #21
prostreetC-10
My Carbon Footprint
This is a board...a forum. Don't post questions and expect no one to answer! lol
It's a good way to keep us all sharp and I believe that more people are learning just from reading your question and our answer. We do this not just for you but all the others that are quietly reading!
A lot of forums won't even let you delete a question after it's been answered so others can learn. Heck, it even lets some of the old timers get into a knowledge face-off.
Lastly....you will find the extesion for the brake pedal under the dash and it's about that long!
Old 02-03-2018, 01:04 AM   #22
wsmolloy
I am not sure what my engine is, I just picked it up of craigs list, The block casting is 3970010 I looked that up and it is a 302/350, The heads I think are double hump casting number 3782461, the number on the right front pad below the head is V1107tyz, Looked up the TYZ and it is a 350 from a 1975 c10-2500. Also it is stamped Langston Racing engines 8-83. Looking like it is a 350, I heard it run before I got it and it definitely has a cam in it. Anyone else have any idea, with the Langston racing stamp it sound like it is a modified 350.
wsmolloy is offline   Reply With Quote
Old 02-03-2018, 08:39 AM   #23
scott123
I bought a small handbook with chevy casting numbers once and for years it was with me at every swap meet or on every parts hunt.
The 010 casting is basically a 4" bore block as stated both 2 and 4 bolt.
In most applications 4 bolt is for mostly for the owner's warm fuzzies.
Scott
scott123 is offline   Reply With Quote
Old 02-03-2018, 11:12 AM   #24
Alex V.
Alex V.'s Avatar
Ehh, wrong. The 010 sitting in my Suburban is a 2-bolt - it can be either.
This is known as the casting number - doesn't nail down much except that it's 4" bore which was common to the 302, 327, and 350. Good block but one of the most common.
Alex V.
1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs.
1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue.
Alex V. is offline   Reply With Quote
Old 02-04-2018, 10:23 AM   #25
wsmolloy
So I am tiring to figure out what engine I have. I was told it was a 327 when I bought it. I know the blocks are the same so how can I tell if it is a 327 or 350?
