06-20-2009, 03:30 AM | #1 |
Gettin It One Pice At A Time
blower motor
is there a way to completely shut off the blower motor? mine is always running! even with the switches off and in the cold zone. it sure does make the truck hotter. lol its like its on really low setting.
RIP ELJAY Work In Progress 1979 GMC C1500 Trailering Special. Getting the truck done, one piece at a time. “You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan “I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby |
06-20-2009, 04:25 AM | #2 |
the pollock
Re: blower motor
are you sure you dont just have a vent issue? where maby the vaccum lines are screwed and leaving them open?
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
06-20-2009, 10:37 AM | #3 |
Re: blower motor
You could pull the fuse, or better yet, disconnect the lead wire going to the motor.
06-20-2009, 11:16 AM | #4 |
Old Heap Driver
Re: blower motor
i know what you mean about the blower. I've been working in and around my dash the last few days, you're right, it runs every time the key is on. Thinking about a simple toggle switch, make sure it's a high amp switch, to turn it off. I don't want to pull the fuse,getting caught in the rain, no ac, i may need the defroster/blower.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
06-20-2009, 12:22 PM | #5 |
the pollock
Re: blower motor
another one was a few years ago, my buddy on his 76 put the wrong vauums lines in the holes so his heatercontrols would only blow heat.... we did not notice this until we were on the HWY in the summer with the windows stuck up......
it sucked.. id check and fix the problem before jury rigging it... jsut my two cents
06-20-2009, 12:57 PM | #6 |
Re: blower motor
This old blower motor thread might help.
http://67-72chevytrucks.com/vboard/s...ghlight=blower PilotJ had an easy fix. “I had the same issue with my '79 ex-ac equipped c-20. There is a plug on the heater box under the hood that has a light blue, dark blue, brown, and yellow wire running to it. I just yanked the yellow wire and that just did away with the low speed. I still have medium and high-speed blower, but no low speed. Works out fine for me.”
Stock 75 C10 step side. 350 2 BBL, 350 trans. 150K miles. |
06-20-2009, 02:54 PM | #7 | ||||
Re: blower motor
I was looking online because I was bored and I came across this! and it made me wonder if the relay could be broken?? or...? my truck does have "ac" but I took the belt off the pump because it didn't really work.
RIP ELJAY Work In Progress 1979 GMC C1500 Trailering Special. Getting the truck done, one piece at a time. “You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan “I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby Last edited by 79gmcc15; 06-20-2009 at 02:56 PM. |
06-21-2009, 05:16 PM | #8 |
Re: blower motor
anyone know the last question?
06-21-2009, 11:08 PM | #9 |
the pollock
Re: blower motor
the link dosent help.. it leads me to an autparts site asking my addy
and umm IIRC the relay is shorted out yes it can cause a constant hot to your blower.. but i would still check and see to make dang sure that the doors are operating properly... just my .02
