Old 06-21-2009, 10:45 PM   #1
donelan07
Active Member
donelan07's Avatar
Steering Wander. Play in steering box?
My truck really wanders bad both ways at 45mph. Should there be this much play in my steering box? I looked at another truck and it seemed to be the same way. Hopefully the video works. thanks
looks like u just have to click the photo to watch the video.
_________________________________
1972 Chevy SWB 4x4 350 4speed
donelan07 is offline   Reply With Quote
Old 06-21-2009, 10:59 PM   #2
Skirkpat
Skirkpat's Avatar
Re: Steering Wander. Play in steering box?
Please do not drive that untill you get a rebuilt steering box, and no it should not have any play like that. If that shaft moves your tires should also.
Skirkpat is offline   Reply With Quote
Old 06-21-2009, 11:25 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
there is supposed to be play in the gear box, but that is possibly 50% more than designed, but is also pretty typical.
Non power assist usually have twice that, those boxes are always worn out bad.
Old 06-21-2009, 11:29 PM   #4
69GMCLonghorn
69GMCLonghorn's Avatar
You can also adjust them instead of getting them overhauled. I've had TONS of play taken out just by having someone with more of a brain that I have get in there and adjust the worm gear. Try that first. If the play can't be adjusted out, then it's time to get it rebuilt.
69GMCLonghorn is offline   Reply With Quote
Old 06-22-2009, 12:44 AM   #5
Sammy
I remember reading about adjusting a place on top of the gear box for excessive play. Believe I read that in the overhaul manual..I wouldn't drive that till you addressed that.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 06-22-2009, 01:44 AM   #6
long69
i have plenty of play in mine, maybe not as much as yours maybe as much. mine does not wander too much.
long69 is offline   Reply With Quote
