1972 C/20
Will not start intermittently
So I think I have a switch going out somewhere. Almost every time I turn the key to start the truck, nothing happens, no clicks, just my "brake" light lights up on the dash. I am thinking it is a column switch, I forget the name, the one that prevents the truck from starting in any gear except park and neutral. I think it might be that because if I move the shifter around and cycle it throughout the gears and back into park it will start eventually.
Are these switches prone to go out? Also, the ignition switch tumbler was recently replaced (Jan), maybe it was a bad install and that is causing the problem. Has anyone had similar problems? Thanks! Last edited by cadillacart; 06-21-2009 at 11:36 AM. Reason: I am from bizarro world sometimes |
Active Member
![]() Join Date: Jul 2007
Re: Will not start intermittently
Yes, they do go out. I had to replace mine years ago, and someone on this site just had to do the same a couple of weeks ago. Definitely need to check that out.
It's called a neutral safety switch.
Easy to jump it also makes a decent way to use it as a anti theft device too.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
1972 C/20
Great, now I have something to do this week.
Thanks! |
