Old 06-22-2009, 09:21 AM   #1
edin355
need help on tilt column
I bought a tilt for my 72 swb from a person named Scott I think several months ago.The plastic part of the back of the signal switch broke inback.I was told I need a special puller to take the tilt apart to take the signal cancellars apart and out of the column.Any help on this would be appreciated.Thanks in advance. Ed
edin355 is offline   Reply With Quote
Old 06-22-2009, 10:19 AM   #2
GruntMoanCough
GruntMoanCough's Avatar
Re: need help on tilt column
Not a puller but, a tool to press the steering lock ring down to remove the clip holding it.
My goal in life is to be as good a person as my dog already thinks I am - Unknown
GruntMoanCough is offline   Reply With Quote
Old 06-22-2009, 10:27 AM   #3
GruntMoanCough
Oh yeah, you'll probably need a steering wheel puller first.
Old 06-22-2009, 01:25 PM   #4
edin355
Where do I get the tool to get the snap ring out. And is the plastic part that has the wiring the same as a non tilt cloumn? Thanks for the info.
Old 06-22-2009, 01:51 PM   #5
bobjob
its real easy...
1.. remove battery cable 2.. remove horn button 3..use puller-remove steering wheel 4..use press to compress spring..5.. remove clip..note no special tool necessary,,as clip is held in place 1/2 on shaft & 1/2 held in place by grove in plate..
..you should NOT.. have to take apart tilt area..
turn signal cam plate is held in place with 3- 4 philips screws..
be sure to unscrew lever first..
reassemble in reverse order..
bobjob is offline   Reply With Quote
Old 06-22-2009, 03:00 PM   #6
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
Now if your column is for a 72 there is no lock plate or retaining clip these are used in 73 up with locking steering wheel. yes wiring is same for tilt or non tilt.
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
02 Silverado ext cab. DD
RIP EL JAY
KevsClassics is offline   Reply With Quote
Old 06-22-2009, 04:02 PM   #7
GruntMoanCough
Yes, I hadn't rebooted my 'computer' yet................ ,
I don't know who sells them but, I made mine out of a piece of 1 1/4" x 3" O.D. channel with a hole in it.......Not sure if the parts are the same for tilt/non-tilt.
