![]() Join Date: Aug 2006
Body mounts, help
I have a new body mount kit and I read on here that a 7/16 bolt is used for the core support mount. Is this correct?
(I would think a bigger bolt would go there. The hole is bigger.) Then does the tallest bushing go under the firewall? The short fat one for the core support? I know all the back bushings are the same, just questioning the front two positions. Thanks, some pics: finally coming back together ![]() |
Re: Body mounts, help
When I did mine I put in the biggest bolts I could, bigger IS better
![]() I also used nylon lock nuts to keep them from comming loose. Do NOT over tighten your mounts, you want them nice and snugg but don't pinch or squeeze the mounts too much. They need to flex. Sorry I don't remember wich mount went were?? ![]() ![]() ![]()
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks ![]() |
Wow, off topic, but what color is that on your K5? I like it!
New Member
The 2 front are 7/16, the 2 front floorpan are 9/16 and the rest are 3/8. I couldn't find 9/16 when I did mine but 5/8 worked fine. I went with poly mounts and the stock length bolts only worked in a few places. I had to get longer bolts for all but 4 spots.
Blaze-Air
Thanks for all the info!!!
![]() I had the front two mounts reversed. Thanks, the color is 2009 Dodge charger r/t model. Took it out of a Chrysler color chart. It's a metalic so looks great in the sun... ![]() |
Thank's, looks good! Keep us posted!
Stealing the thread...I'm about to do the same, trying to decide what is better, rubber or the poly. My main concern is I've read the poly squeak after a while, true? Thanks, hopefully I can order them and get it done this Saturday.
#9 | |
Might be a day late to the party but here's a body mount assembly page. |
