Old 06-21-2009, 02:58 PM   #1
onlyifihadachevy
my trucks broke again
the front blew a bearing a few weeks ago then yesterday my truck broke the rear u bolt. Causing the driveline to crack the rear output shaft on the t case, now i think i want to get something else to mess around offroading and have my current truck tow that out there.
72 gmc 2500 2wd drive convert
My 72 thread
http://67-72chevytrucks.com/vboard/s...d.php?t=346712
THe other truck, wheeler 69 1/2 4x4, yellow and rusty.
http://67-72chevytrucks.com/vboard/s...d.php?t=350300
onlyifihadachevy is offline   Reply With Quote
Old 06-21-2009, 06:35 PM   #2
msgross
msgross's Avatar
Re: my trucks broke again
that doesn't sound like an easy fix...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 06-21-2009, 08:21 PM   #3
sound like time for a slip yoke eliminator kit.
Old 06-21-2009, 09:24 PM   #4
onlyifihadachevy
i think the plan is to see what i can do tomarrow and buy a 69 1/2t short stepside, within a week or 2.
My 72 thread
Old 06-21-2009, 11:29 PM   #5
dammitmitchell
the pollock
dammitmitchell's Avatar
wtf? you keep "buying"... why not be patient and FIX?
do NOT condemn a entire truck to being a potiential barn find or a "cube" when you get tired of it..
this site is entirley dedicated to helping you youngin's and (well ima youngin too) and the olders and unknowing to have all the resources they need to fix their vehicles.
if your truc was a 2x4 to 4x4 conversion ther is a good chance someone screwed up...
just be patient and fix it..
not ot upset you.. but man.. ive had a jeep for OVER 10 years that dosent run.. i will NEVER cube it.. because i can fix it myself.. when GOD/ my wife/ and my children give me the time i would need to finish it..
thank you for dealing with my rant..
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 06-22-2009, 03:20 AM   #6
84 400
Sb 400 club
84 400's Avatar
hmm yeah I would fix it which it sounds like ur planning on doing . Heck when i got my truck there was no rear diff fluid....... After seeing it is a 2wd convert i would go through everything.. One of the "joys" of offroading is breaking. thats why i love wheeling other peoples trucks. With these heavy chevys it does not happen as much as it does with the jeeps but it happens. A truck to just off road and one to tow with is a good idea if you can afford to do it. That way you are not totally bummed when it is down. Its only parts you'll get it fixed
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 06-22-2009, 06:45 AM   #7
You have to realize,a ll wheeling for fun is abuse.Just seeing what it`ll do is.To be able to go out and have fun with confidence of making it without breaking it requires tip-top condition of drivetrain along with upgrades and,most of all,knowing the limits of what you`re working with.Busted axle u-joints are common when tires are larger than recommended as well as with any wear in that area.I mean worn ball joints and spindle bearings as well as the u-joints themselves.
The tail shaft on aluminum t-cases is common,too,on lited rigs.I`m not familiar with your truck or how it was converted,but if I could look at it I`m pretty sure the cause would be obvious.But,one thing most do when lifting and wanting an off road ready rig go with a slip yoke eliminator kit.It`s a vulnerable design for those who like to "field test" their rigs.Then,there`s always going to the bulletproof NP205.It all depends on how serious you are about your wheeling.
I went out and busted up my stuff until I got tired of throwing money at my stuff.I just started taking it easy and wheeling very little.It`s either throw money to prevent problems or go for it and throw money fixing it.Four wheeling put`s everything to the test.The factory intention for 4wd is to allow a vehicle to double the traction of a 2wd to enhance what a 2wd was intended to do.They never came with large tires for a reason.they never came with upgrades to enhance off roading for a reason.They know we`ll just take it to the next level and break it anyway.When they see evidence of "wheeling" they void your warranty.You`re on your own when wheelin`.
Old 06-22-2009, 11:23 AM   #8
onlyifihadachevy
The front will get fixed when i find a d60 from a chevy because the ford dont have u bolt on the pumpkin, and i have 2 3rd output tcase. A 205 and one with a pto belive its a 205 maybe rockwell, and i found that the rear spun the perchs causing everything.
And i am going to fix and use this to tow. That way i dont have to pay a 125 fee to tow it.
My 72 thread
Old 06-22-2009, 08:59 PM   #9
onlyifihadachevy
I wok on it for a little in my build/ ix thread but i found out that the crack is not as bad as it looked so it should be fixed tomarrow.
My 72 thread
Old 06-23-2009, 12:08 PM   #10
onlyifihadachevy
Pics are up. in the fix build thread
My 72 thread
