Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 06-02-2009, 09:05 PM   #1
1970chevy
555 bbc
i got my 555 with 13to1 pistons ready i am running c16 at the track just wondering if i can run 93 octane with booster on the street if i back the timing off thanks
1970chevy is offline   Reply With Quote
Old 06-03-2009, 01:44 AM   #2
worley91
Big Boys With Big Toys
Re: 555 bbc
I'd say no
worley91 is offline   Reply With Quote
Old 06-03-2009, 08:10 AM   #3
djracer
djracer's Avatar
Re: 555 bbc
a 13 to 1 piston doesn't mean you have 13 to 1 compression. Do you know deck height, head gasket, bore, stroke, head cc, dome cc, and so forth. If I was gonna drive it on the street I would run Av gas with 1 ounce of marvel mystery oil per gallon.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 06-03-2009, 09:37 PM   #4
ProStreet68SB
The Engine Whisperer
ProStreet68SB's Avatar
Re: 555 bbc
pardon my ignorance, but what is the marvel mystery oil going to do?
ProStreet68SB is offline   Reply With Quote
Old 06-03-2009, 10:30 PM   #5
1970chevy
Re: 555 bbc
i dont know i am thinking that av fuel bruns dry and the oil will gave you some lube
Old 06-03-2009, 10:31 PM   #6
kwhite4
Junior Member
kwhite4's Avatar
Re: 555 bbc
Its a Mystery LOL
Sorry couldnt resist...
68 GMC
565 BBC
Abruzzi super pro glide
9.85@135.00
kwhite4 is offline   Reply With Quote
Old 06-04-2009, 07:36 AM   #7
djracer
djracer's Avatar
Re: 555 bbc
Exactly!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 06-04-2009, 08:00 AM   #8
Alex1
Alex1's Avatar
Re: 555 bbc
Octane Booster is no good. with 13:1 back off the timming and see. it will idle and at light loads you MIGHT be OK but you're just looking for trouble. You could try water/meth injection or run good gas all the time.
Alex1 is offline   Reply With Quote
Old 06-04-2009, 06:33 PM   #9
Lx3
Lx3's Avatar
Re: 555 bbc
No na NO NO NO
If you don't know true pressure it's a Big Gamble.
9:1 {pressure} is about it without some other factor IE: water
Lx3 is offline   Reply With Quote
Old 06-04-2009, 10:11 PM   #10
djracer
djracer's Avatar
Re: 555 bbc
A buddy of mine had a 13 to 1 440 in 70 duster back in the day and he ran av gas.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 06-07-2009, 12:28 AM   #11
Tom
driving is in my blood
Tom's Avatar
Re: 555 bbc
Theres 91 and 100 octane avgas. Don't use the wrong one.
Old 06-07-2009, 08:56 PM   #12
1970chevy
Re: 555 bbc
i just pick up some 100 octane av i back the timing seems to run good just hve to play with jetting again
Old 06-23-2009, 05:21 PM   #13
ulakovic22
Re: 555 bbc
Carb and size, fuel injection, computer, HEI, Aluminum heads or cast iron, etc. There are some details you left out. If you want a response based on a guess, I would say you can, but you will have to back the timing off so much it would run like crap.
ulakovic22 is offline   Reply With Quote
Old 06-23-2009, 06:55 PM   #14
mongoose
mongoose's Avatar
Re: 555 bbc
do you have e85 where you live, be right at home in that motor.
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
