profeshinaly unimployed
wire
my ground wire doesn't look too great ...alot of the outside rubber is chipped away and is just plan used and abused lol so i was wondering would a 4gauge amp power wire be good enough for my ground
"having mud flaps is like asking for a smaller trophy" |
Re: wire
as long as the wire you are using for ground is the same size or bigger than your positive cable it will work just fine. 4 gauge should be plenty good bro.
www.myspace.com/thehouseofhack www.thehouseofhack.com www.myspace.com/minitruckin_mat ![]() |
Re: wire
Re: wire
Ensure your bonding wire from the cab to the engine is good, along with the ground from the battery to the front radiator support.
I feel sorry for people who don't drink....because when they wake up in the morning, that's the best they're gonna feel all day long!---Frank Sinatra RIP [B]1972 Chevrolet K5 Blazer RIP 1986 GMC Sierra K3500 1TON, Long Box, V8350 RIP 1980 Chevy Silverado C30 Cab and Chassis, 454 TH400HD. RIP [B] 1995 Chevrolet Tahoe 2D [B] |
Cheyenne Super
Re: wire
It won't hurt for the insulation to be gone on a ground wire.
If it's corroded you should replace it though. Check you'r pos cable while you're under the hood, the insulation on it could be on it's way out, and with the fuel leaks you have, you don't want any sparky sparky. ![]() |
Kid's Mechanic
Re: wire
Using the cable is fine but what about the Terminal ends?? Pinching the cable under the head of a bolt isn't a permanent fix.
Re: wire
Battery cables should have the ends soldered to the terminals. Remember, Bad connections cause resistance which causes heat, which causes more resistance, which causes more heat, which causes more resistance..... If you can get a voltmeter, use the OHM setting to find out how good your connections are.
