Differences in frames between K20 and K30?
I have always wanted a K30 4x4, I have owned lots of K20 4x4's. Was there any difference between frames on the K20 and K30 or was just gvrw numbers? What all other differences were there? I know a 3\4ton could be ordered up to have all the big drivetrain, radiator and such, but is there any other real differences? Great site, enjoying mysef here!
thinair
![]() Join Date: Jun 2004
Re: Differences in frames between K20 and K30?
1 ton frames are taller than the 3/4-1/2 ton frames and the rear spring hangers are spaced further apart..........otherwise,mounts and such are all the same
So the frames are the same thickness and width, they just vary in height between the 1\2 3\4 and 1ton. And the leafs are longer. Any other onfo? Thanks for all the help!
my undestanding was they were taller and a tad thicker.
1995 GMC 4x4 1/2 ton 1999 Jeep Wrangler w/ 33's 68 camaro 350/350 1987 Chevy 3/4 ton 4x4 Suzuki DRZ 400s Dual Sport 1971 chevy long bed 2x4 194? Dodge 2.5 ton 1980 Chevy Cheyenne 4x4 1/2 ton I6/sm455 1989 Chevy V30 crewcab dually 454/TH400 |
Arrived on a Pale Horse
Can't really comment on the differences. The two trucs in my sig sit at the same height. The v30 (gm dropped the "k" in 87 for a "V") is bone stock suspension. The 79 has a four inch suspension lift, springs in front and blocks in rear, and 33 inch tires. I can get a couple pics tomorrow, but the are same height. (approx)
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
#6 | |
You could not order a 3/4 ton with the Dana 60 front axle. The frames on a 30 series are bigger. The 1 ton comes standard with hydroboost brakes with all engine configurations. Other series GM light trucks had hydroboost with the diesel engine only. |
profeshinaly unimployed
whats the differences between a 1/2 ton and a 3/4 ton...junst wondering
"having mud flaps is like asking for a smaller trophy" |
I have had a few K20's with dana 60 fronts, are you sure you couldn't get one like this?
Heavier duty springs, eight lug wheeels and a bigger rear axle. Front axle was the same.
1986 Chevy 3/4 Ton 4X4 ![]() |
#10 | |
Not factory. Someone swapped them in over the years, or could have been a rebadged 3/4 ton.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
Shurly the 3\4ton and 1\2ton didn't share the same frame?
Yes they surely did.
#15 | |
#16 |
first is the K20 frame, right in front of drivers side rear wheel, second is 87 30 same frame location.
#17 |
Thanks for the pics!
