i got no spark..
well i made my plug wire ends.. stuck them on and the gold part connectors were to big so i bent them to a smaller circle.. and they wouldnt work so i made my old wire from my point set work..they fit on and everything go to fire it up and i got no spark... we used the wire off my coil for our source
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
LET'S GO RACIN'
![]() Join Date: Oct 2007
Re: i got no spark..
Hey Tim you need to use a different spot on your fuse block for the power wire. The old coil wire does not have enough voltage running through it. Need to find a 12 volt spot on your fuse block for the power wire. You should be able to pry your connectors open so they can fit on your plugs. If you need help me and Ken can come over tomorrow and help.
Daren 04 Chevy Extend cab 2500HD 6.0 Liter 4x4 71 CHEVY 3/4 4X4 402 BB, th400/np205, dana44/eaton ho52 w/4:10-TOY ![]() Rip El Jay RIP BOBBO'S MOM |
could i run a hot wire from battery? the wire was from the coil we thought that would have enough juice but it didnt ya u can ill give ya a holler when i get off from brians.. i think i am changing plug wires again.. gotta buy new ones i fubar'ed the new ones..
My Carbon Footprint
This kid is a trooper though!
i aint no quitter.. i have been fighting for almost 8 months to get this project done
LET'S GO RACIN'
No, you need to find one on the fuse block. The battery would be a constant voltage. Ya need one that turns off with the key. Were your other wires new or from something else? If your going to go buy new ones, get a set of msd wires. That is what i use and they work good. He definitely gives everything a good effort. Give me hollar after work, get off at 5:00 right? Did your headers come in?
Daren 04 Chevy Extend cab 2500HD 6.0 Liter 4x4 71 CHEVY 3/4 4X4 402 BB, th400/np205, dana44/eaton ho52 w/4:10-TOY ![]() Rip El Jay RIP BOBBO'S MOM Last edited by 88JRFAN; 06-24-2009 at 12:19 AM. |
ya my wires were new but the guy i know form autzone put the ends on them and i think they were the wrong ones.. and i dont got the other ends no more.. i got theses ones because they are yellow since the truck is going to be yellow i figured why not... but ya 5 is when i like to get out of work
LET'S GO RACIN'
Which ends did he put on? 90 degree's or straight's? Finally decided on color, good to hear.
Gearhead and audio junkie
Just take a look at your fuse box get a multimeter and turn the key to on find a source that gets 12v splice the wire run it to the side that says BATT on the HEI distributor (that is if its a GM one) or the positive side connect it, check again that its getting 12v, crank it up get ur timing set and yah should be rollin'
Restoration Virgin!
Tim,
I helped a guy setup his HEI.....I read a FAQ thread and used this unfused source....try that.....We added a single plug connector on both ends...connecting one here and the other on the 'BAT' side of the dizzy....hope this helps!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present Last edited by gcburdic; 06-24-2009 at 08:32 AM. |
Under Construction
if you run it from an unfused circuit, should you run an inline fuse?
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
Restoration Virgin!
here's the FAQ thread I used....http://67-72chevytrucks.com/vboard/s...ad.php?t=13698
According to the FAQ....YES....run a BIG fuse....it says 30A.....
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present Last edited by gcburdic; 06-24-2009 at 08:47 AM. |
ok thanks guys ill do this tomorrow.. i went 2 hours away tonight to pick me up a complete truck bed for $350.. so.. anybody need some bedsides i just needed the floor
